where would you go to get a hilux diff shortened
Postby 70ke25 » Tue Aug 10, 2004 8:18 pm
its for a 1970 ke25 coupe with a sr20 in it
70ke25
Postby atmosports » Tue Aug 10, 2004 9:17 pm
I'd try the likes of Diffspec in east tamaki, Diffs'r'us in Otahuhu. They'd be my picks in Auckland. Outside of Auckland I'd be looking round & asking the V8/Hotrod guys of a good Diff place. Failing that you could get a fab/welding shop to shorten the axle tubes foryou & then take the axles into a machine shop & get them to respline the ends once they've cut them to length
atmosports
Postby Logan » Tue Aug 10, 2004 9:35 pm
Ive heard people talking about it but never invesitgated, some 4wd vechiles have offest front diffs, and there is a possibilty of using two short side axles in a shortened housing, which means only shortening one side of the diff. Not sure how this applies to toyotas, but it could be possible.
Otherwise in your case really is a matter of where you are.
SR Sold. Onto Other Things
Logan
