got a heavy duty clutch
Postby Roman » Thu Aug 12, 2004 10:57 pm
Hey guys I got a heavy duty clutch,and I was wondering do I have to run the clutch in for round 1000k's? do i have to drive like a nana? or can I go lil bit hard? is there anything to watch out for?
Roman
Postby solberg Fan » Fri Aug 13, 2004 12:27 am
I was told to go easy on it for the first 100ks. But that was a normal road one. But id be interested to here what other people say, as ive got a new paddel clutch waiting to go to.
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
Before you judge someone, you should walk a mile in their shoes. That way, when you judge them, you're a mile away and you have their shoes.
solberg Fan
Postby Al » Fri Aug 13, 2004 1:14 am
I've been told two different things. My mechanic and part time rally driver told me when he put my TRD brass button in 'its a brass button clutch, you dont need to wear it in, you're not gonna break it'
But others have said 'go easy for the first 1000-1500kms, no launching, slapping gears at full throttle etc'
Al
Al
Postby badidas » Fri Aug 13, 2004 9:46 am
bothe the clutch and pressure plate should be new so i wouldbe inclined to take it easy for the first 1000 kays to bed it in .
1989 mazda bongo aka [BNGBUS]
badidas
Postby TRD Man » Fri Aug 13, 2004 10:16 am
If it's a TRD paddle put it in & drive it. It'll work fine straight out of the box.
If you mucked around for 1500k's, that's a season of racing to most people.
TRD Man
Postby evil_si » Sun Aug 15, 2004 7:24 pm
clutches shouldnt need running in, getting them hot and making them work is all they need.
you dont want them to glaze by being a nana
evil_si
Postby Monsterbishi » Sun Aug 15, 2004 8:12 pm
evil_si wrote:clutches shouldnt need running in, getting them hot and making them work is all they need.
Depends on how well they're made, the run-in time is also to allow the studs to bed into the friction material properly.
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby NZ_AE86 » Sun Aug 15, 2004 9:22 pm
Some clutch types do need 'bedding'. 8O
Similar to brake pads, if you do not bed it in it is not to say that it will not work but it will not perform to its full potential. :D
NZ_AE86
Postby rage » Sun Aug 15, 2004 10:25 pm
what about a 5 puck ceramic clutch ?
was told 1000kms is this true ? cos then i have another 700kms to go :/
rage
Postby Monsterbishi » Sun Aug 15, 2004 11:50 pm
rage wrote:what about a 5 puck ceramic clutch ?
Better safe than sorry, remember, open road driving doesn't count, and unless you want the clutch to wear out in 5 minutes flat, don't slip it, button clutchs must be driven like a light switch - on/off - no slipping.
--- Cut Here ---
Monsterbishi
Postby rage » Mon Aug 16, 2004 12:40 am
whats counted as slipping ? its kinda hard to drive if you dont slip it, especially when taking off... dont like hte prospect of dumping it every time i move off from the ligths or in traffic.
rage
Postby Al » Mon Aug 16, 2004 12:42 am
well you dont dump it from high revs, i just blip mine to around 2000rpm and as the revs fall i step off the clutch, works a treat most of the time
im gonna have to slip it at drags tho, theres no other way of getting cleanly off the mark....will be a fast slip tho, like 1st to last amber then off clutch
Al
Postby rage » Mon Aug 16, 2004 6:14 pm
yup havent been dumping it at all. except for mistakes. still getting used to it.
rage
Postby FLAWLES » Mon Aug 16, 2004 7:13 pm
i have just been through this
you dont have to bed them in
u just have to learn how to drive with them
pain the the a-whole in heavy traffic good for dragging and racing
FLAWLES
Postby NZ_AE86 » Mon Aug 16, 2004 9:04 pm
You do have to bed almost all 'race' type plates. This involves slipping the clutch, quite a bite of stop start driving is good, but you don't want to introduce too much heat.
Although most people over clutch their cars so will never have a slipping problem. If you bed your clutch in it will bite better and hold tighter for longer. :D
NZ_AE86
