4ager conversion in a dx corolla
Postby dx_conversion_4age » Mon Aug 16, 2004 11:02 pm
Ive just got into corollas and relly keen to do an engin tranny in a dx corolla staion wagon. I would relly apreciate any help i can have reguarding all the parts needed to do the conversion. thanx. the info that ive herd is that you need a 4age (of course) don't know which one though, a t50 gearbox and different engin mounts. any help will be much apreciated thatnx!!
dx_conversion_4age
Postby kingcorolla » Tue Aug 17, 2004 12:17 am
not that hard really, 4a-ge in a ke70 s/w is my current project aswell!
to sort out what 4a-ge u want to buy, this site is great for deciding
http://www.geocities.com/MotorCity/7177/4ageengines.html
and ure rite a t-50 box is great for medium modification, but u need one that will bolt on to an "A" series engine, remember that when buying.
as for mounts, no fabrication required. u just need the crossmember and engine mounts from either an AE86, or an AE70 (KE70 sedan, but with 3A-U engine) They will bolt rite in to ure wagon.
if u have anymore questions just ask, ill be glad to help get another KE70 project on the way!
1983 Carina AA63 4age
kingcorolla
Postby dx_conversion_4age » Tue Aug 17, 2004 8:34 am
cheers that helps me out alot. so the standard diff is ok?? is there any mods that need to be done to the gearbox to fit it in or is it pretty easy to do. ive also been told that it is a very costly thing to get all the computer and wiring setup and installed do you know anything bout this??
dx_conversion_4age
Postby matt dunn » Tue Aug 17, 2004 8:55 pm
dx_conversion_4age wrote:cheers that helps me out alot. so the standard diff is ok?? is there any mods that need to be done to the gearbox to fit it in or is it pretty easy to do. ive also been told that it is a very costly thing to get all the computer and wiring setup and installed do you know anything bout this??
Where abouts in NZ are you?
Postby dx_conversion_4age » Wed Aug 18, 2004 12:33 am
im in auckland, north shore
dx_conversion_4age
Postby kingcorolla » Wed Aug 18, 2004 12:59 am
for a little more 'extensive' info, check out my post on this guys topic...
http://forums.toyspeed.org.nz/viewtopic.php?p=183852&highlight=#183852
same thing really. As for the loom well if u have to fork out for an auto sparky to do it, well sometimes u just have to! at least u know its done rite, and if not, its not ure bad. but yea it is pretty expensive. Hopefully ure as lucky as me, and have an old workmate (mechanic) to do it for beans!!
good luck
anymore questions, just ask
[/quote]
kingcorolla
Postby MetalupYoAss » Wed Aug 18, 2004 10:18 pm
wiring is easy, just extend the loom by about 300mm and connect 4 wires into your existing wiring loom
MetalupYoAss
Postby kingcorolla » Fri Aug 20, 2004 8:41 pm
MetalupYoAss wrote:wiring is easy, just extend the loom by about 300mm and connect 4 wires into your existing wiring loom
??? 4k dont have an original loom... its got single downdraft aisan carb
u just need 4A loom and mount the ECU in the footwell, and route wires through fire wall
kingcorolla
