Is there a difference between afms???
Postby Sharpy » Wed Aug 18, 2004 9:10 pm
I need an afm to work on my 4agze aw11, and have been offered one from an ae92 model. will this work?????
Turn it up!
Sharpy
Postby Twolitre » Wed Aug 18, 2004 10:23 pm
It will most probably work knowing Toyota, but you might want to compare it with your stuffed one to make sure the internal air passage isn't much if any smaller, if not an AFM from a 3SGTE Celica/MR2 might be worth a look.
Twolitre
Postby CozmoNz » Wed Aug 18, 2004 11:10 pm
new ecu and grab a map..
afms are restrictions :P
Rayne For President!
CozmoNz
Postby Bazda » Wed Aug 18, 2004 11:59 pm
yes the ae92s afms should be the same as the aw11s.
afms not that bad :(
I run an afm on my car, maybe get more power if i didnt....who knows it seems to be doing the job more than enough and it seems to handle the boost as well :evil:
Users browsing this forum: No registered users and 49 guests
