engine bay wires
engine bay wires
Postby minijrocks » Sun Aug 22, 2004 3:12 pm
Hi, do wires in the engine bay, such as alarm wires, need to be heat resistant or can any covered wires that you buy do? do they have to be special heat proof ones? (the wires are only around the back perimiter (firewall))
minijrocks
Postby CozmoNz » Sun Aug 22, 2004 3:59 pm
for what reason, wires in the engine bay dont get very hot at all really... and if they do, the things attached to them wouldnt work :P and ive never known of an ecu or alarm not working because the wires are to hot....
hot wires = high resistance, high resistance = no conductivity = no current :P
Rayne For President!
CozmoNz
Postby minijrocks » Sun Aug 22, 2004 4:11 pm
so i can just use standard wire like they use? pretty much like speaker wire? also, whats that heat shrink stuff? is it just to hold a whole heap of wires together? so its kinda organised?
minijrocks
Postby CozmoNz » Sun Aug 22, 2004 4:15 pm
heatshrink is usually used to insulate, eg, put it on the ends of leds (since they dont come with insulation) after soldering it to something, so it cant touch ground and short out.
i dont see why you cant use normel copper wire....
depends on what u want to use it for, an amp or something requires MASS cable... heaps of current.
CozmoNz
Postby minijrocks » Sun Aug 22, 2004 4:59 pm
nah its not for an amp, just making sure my wires dont melt :D thanks for that.
minijrocks
Postby kingcorolla » Sun Aug 22, 2004 7:30 pm
ye heatshrinks the way to clean up ure dodgy head unit wiring ay!! GUILTY :oops:
..the old twist 'n' twine....
1983 Carina AA63 4age
kingcorolla
Postby minijrocks » Sun Aug 22, 2004 8:46 pm
hahaha, twist and tie.... but at least i covered it up with some insulation tape :D all good
minijrocks
Postby kingcorolla » Sun Aug 22, 2004 10:13 pm
minijrocks wrote:hahaha, twist and tie.... but at least i covered it up with some insulation tape :D all good
and using a lighter for a wirestripper anyone??? very effective :D :D
kingcorolla
