3k flywheel etc onto 4age?
Postby l1ttle_d3vil » Sun Aug 22, 2004 10:14 pm
just wondering if a 3k flywheel, clutch and pressure plate will fit onto a rwd 4age engine? or will i need to get them from another 4age engine?
and also will my original 4speed gearbox off the 3k engine bolt up to a 4age?
cheers :lol:
Re: 3k flywheel etc onto 4age?
Postby matt dunn » Sun Aug 22, 2004 10:53 pm
l1ttle_d3vil wrote:just wondering if a 3k flywheel, clutch and pressure plate will fit onto a rwd 4age engine?
cheers :lol:
no
yes
and no
Postby l1ttle_d3vil » Mon Aug 23, 2004 8:18 am
thanks for that. :D
Postby l1ttle_d3vil » Mon Aug 23, 2004 9:05 pm
does it matter if i get the flywheel etc off a fwd or rwd 4age? (its to go onto a rwd setup)
and will the dizzy off the 3k engine go onto a 4age? i heard dizzys from 4ks will fit straight onto 4ages so im guessing they'll be the same...
thanks
Postby MetalupYoAss » Mon Aug 23, 2004 10:55 pm
nope you can use front or rear wheel clutch setup, both the same, k series distributor wont work.. why would you want to use a 3k one anyway?
MetalupYoAss
Postby MetalupYoAss » Mon Aug 23, 2004 10:59 pm
MetalupYoAss
Postby matt dunn » Tue Aug 24, 2004 12:31 am
l1ttle_d3vil wrote:does it matter if i get the flywheel etc off a fwd or rwd 4age? (its to go onto a rwd setup)
thanks
Yes fwd or Rwd but not a supercharged one as they wont fit into rwd bellhousing.
You can get a 4k elec dist modified to fit if you are running carbs and need an ign system.
Matt
