gze LSD in AE82 fxgt's c52 gearbox?
Postby ChaosAD » Sat Aug 28, 2004 7:24 pm
Does anyone know if the lsd from a 4agze gearbox will fit in an ae82's c52 gearbox?
ChaosAD
Postby 85AW20v » Sun Aug 29, 2004 9:42 am
No it won't fit. Tried the same thing myself. The GZE crownwheel is heaps much too big and shitloads heavier. Driveshafts are also around 27mm against 22mm for the C52. You can bolt the GZE box up and you need the GZE flywheel and clutch as well. THe GZE box is around 15kg heavier than the C52 and I found that the extra weight outweighed any gains from the LSD around Taupo. Last race meet I did a 47.3 with 20v and C52 in my AW so now I need a LSD to fit the C52 to get any faster.
See ya
Simon
85 MR2 20v
85AW20v
Postby ChaosAD » Sun Aug 29, 2004 3:37 pm
And i'll need to modify my g/box mounts etc to fit that box in.
What about an lsd from an ae111?
ChaosAD
Users browsing this forum: Google [Bot] and 20 guests
