comp ratio... sorry guys
Postby kingcorolla » Sun Aug 29, 2004 3:18 am
i know u have herd this all before, but i ran a search and couldnt be fukkd lookkin through all of them. I want the formula to work out comp ratio. i know its in ure bore + stroke etc etc.
or one of u could do me one better and answer this...
im shipping my short block off to reconditioners for bottom end work on mon, and wanted to increase my BLUETOP compression ratio while im at it. Bluetops are 9.4:1 factory, and i want to increase to red/silvertop comp ratio (10.3-5:1,) for a little more bang.
so can anyone hook me up with a good amount to shave off the block? or at least the formula so i can try and work that mother out for myself? :?
1983 Carina AA63 4age
kingcorolla
ratio
Postby JasonZE » Sun Aug 29, 2004 2:41 pm
You are better off giving them the head and block and have them work it out as you need to cc the combustion chambers in the head to work out the ration between bore and chamber
You can deck the block but you need to plane the head or get a suitable trd metal gasket to achieve the right ratio as you can only take a tiny amount from the block to get the piston deck height right.,
A good reconditioner will be able to do this easily and it would take you for ever as measuring the combustion chamber volume is a slow process. :roll:
JasonZE
Real Life Mechanic
Postby kingcorolla » Sun Aug 29, 2004 7:58 pm
u think if i send my head to a specialist, told him the cc rating of the engine, and the comp ratio, they could take off the rite amount?
kingcorolla
Postby Drifter4ag » Sun Aug 29, 2004 9:18 pm
take 1mm off the head and bang .. your done .. 10.4:1
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
JZX91 MARK II CHASER
Drifter4ag
Postby kingcorolla » Sun Aug 29, 2004 10:11 pm
cheers drifter4ag! thats wat i wanted to hear :D
kingcorolla
Postby CozmoNz » Sun Aug 29, 2004 10:19 pm
you know i really hate you for forcing me to type this out....... but i gotta do this
i hate typing btw, so be thankful
Compression ratio:
A compression ratio is the comparison of the volume above the piston when the piston is at BDC to the volume above the piston at TDC.
The volume above the piston at BDC = v1 = swept volume + clearance volume (SV + CV)
The volume above the piston at TDC = v2 = clearance volume (CV). Compression ratio = v1 : v2 = (SV + CV) : CV = (SV + CV) / CV
It can be shown that the same numerical answer can be obtained from an alternative formula: compression ratio = (SV / CV) + 1.
got it?
Example:
Determine the compression ratio of an engine if the bore is 80mm, the stroke is 100mm and the clearnance volume is 70 cm cubed.
Solution:
Bore = 80mm = 8cm.
Stroke = 100mm = 10cm.
Swept volume = area of bore X stroke
Therefore = (PIE D2 X Stroke) / 4
Therefore = ((PIE X D X D) X Stroke) / 4
Therefore = ((3.142 X 8 X 8) X 10) / 4
Which = 502.7cm Cubed
V1 = SV + CV = 503 + 70 = 573
V2 = CV = 70
V1 : V2 = 573:70
= 8.19 : 1
and that annoying alt soloution:
(SV /CV) + 1
= (503 / 70) + 1
= 7.19 + 1
= 8.19
got it? ^_^ ezy pzy
Rayne For President!
CozmoNz
Postby Al » Sun Aug 29, 2004 10:21 pm
CozmoNz wrote:i hate typing btw, so be thankful
thankful you can cut n paste?
Al
Postby kingcorolla » Sun Aug 29, 2004 10:29 pm
thanx cosmoNZ
that "...sorry guys" in the title was directed to people like you!
*cuts and pastes to desktop*
kingcorolla
Postby RedMist » Sun Aug 29, 2004 10:58 pm
Because I am truly lazy.
http://www.hotrod.com/techarticles/54258/
Aint google grand!
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby 4agepwr » Mon Aug 30, 2004 7:08 pm
Drifter4ag wot headgasket would you use after planing 1mm off to get that comp ratio?
Jappa AE82 Corolla GT Sedan
EX: AE82 NZ New Corolla GT Liftback
4agepwr
Postby CozmoNz » Mon Aug 30, 2004 9:07 pm
excuse me? i typed that out from my notes in my power efficenty papers....
did not cut and paste damnit
CozmoNz
Postby qik20v » Tue Aug 31, 2004 11:05 am
[/quote]
Bore = 80mm = 8cm.
[/quote]
isnt the area of a circle pi * radius squared
not pi*diameter^2 ?
1996 AE111 Toyota Levin BZ-G - 15.1 @ 146km
http://toyspeed.blakjak.net/profiles/profile.php?id=301
qik20v
Postby jayznz » Tue Aug 31, 2004 11:50 am
qik20v wrote:
Bore = 80mm = 8cm.
[/quote]
not pi*diameter^2 ?[/quote]
first of all hehehe 'PIE'
Secondly, qiky you forgot about the little' /4' tacked on the end
r^2 is the same as (d/2)^2
which is the same as d^2/2^2
or d^2/4
Hence the '/4'
So, Cozmoz formula is correct i think
Now children that will be on your end of year tests so i hope ur writing this down :wink:
jayznz
Postby qik20v » Tue Aug 31, 2004 8:33 pm
ok my appologies to CozmoNz
didnt really look at formulas just saw pi*d^2 and was like wtf?
qik20v
Postby Spannergal » Tue Aug 31, 2004 9:05 pm
Drifter4ag wrote:take 1mm off the head and bang .. your done .. 10.4:1
not completely sure coz i hate working things out but don't think its as simple as that. but the specialist is supposed to know how to change the cc and comp ratio
Spannergal
Postby RedMist » Wed Sep 01, 2004 9:20 am
Which is a good question.. has anyone CC'ed a 4age head and piston dome?
RedMist
Postby ChaosAD » Fri Oct 22, 2004 7:53 pm
I cc'd a red\blacktop piston dish. It was 5cc but I dont know what it would be in the engine, that would depend on the piston height.
In the wiseco catalogue it lists the 16v 4age head at 39cc.
ChaosAD
Postby Drifter4ag » Fri Oct 22, 2004 8:54 pm
if your gonna take 1mm off the head just run a std ae92 gasket which is the best of the lot
otherwise get a TRD one .. they plenty good and can be used again and again
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
Drifter4ag
Postby CozmoNz » Sat Oct 23, 2004 2:57 pm
Yeh, i was pretty sure my formula was correct, its what we use...
looks quite complicated, but if you follow it through, its pretty damn easy
CozmoNz
