hey
is it possiable to do a low boost turbo set up on a silvertop?
if so what gear would you recommend, turbo wise etc, still keeping standard rod's etc
rollas22 wrote:ive done this conversion, but went the whole way and rebuilt the engine with stronger internals. One this you can't run much boost on teh standard intake manifold, it will blow the plastic trumpets apart.
I will post up some pics later on when mine completely finished.
