has anyone put a 3sgte engine in a NA sw20 before
Postby ricky » Fri Sep 03, 2004 7:47 pm
Has anyone out there put a 3sgte engine in a sw20 before.
Will it bolt straight in a NA SW20
( I have got some quote from other people and they said it is different but I have seen someone did that before)
ricky
Re: has anyone put a 3sgte engine in a NA sw20 before
Postby anthonym » Fri Sep 03, 2004 8:15 pm
ricky wrote:Has anyone out there put a 3sgte engine in a sw20 before.
The actual engine itself is a straight foward bolt in swap, but you need a lot of other things to make it work, primarily the turbo E153 gearbox, axles and hubs, and the loom (all the way to the dash) computer and sensors. If you have a running donor car it's a simple if time consuming exercise, otherwise finding all the little bits you need can be a nightmare.
anthonym
Postby mr2_t » Fri Sep 03, 2004 8:19 pm
the widely held opinion is that its better to just buy at GT or GTS as the conversion is very expensive if not doing the work yourself.
The turbos are different in lots of ways:
suspension
exhaust
brakes
gearbox
do a search and you will find a longer list...
mr2_t
Postby anthonym » Fri Sep 03, 2004 8:52 pm
mr2_t wrote:The turbos are different in lots of ways:
suspension
exhaust
brakes
gearbox
That's not correct, JDM suspension and brakes are the same. Don't rely on (mis)information from the US.
anthonym
Postby Linz » Thu Sep 09, 2004 6:26 am
ive done this 1 at my old job (autotrans mech) we just got a half cut and the others r right just buy a gt or gt-s it will be cheaper
note the sub-frame also had diffrences
Linz
Postby anthonym » Thu Sep 09, 2004 8:09 am
Linz wrote:ive done this 1 at my old job (autotrans mech) we just got a half cut and the others r right just buy a gt or gt-s it will be cheaper
Not necessarily, depending on the cost of the parts, if you can get a damaged car out of Japan for the right money a swap can be very cost effective, especially if you get a gen 3.
There are no differences in the subframe between turbo and NA, but it was changed for all models with the 12/91 model revision.
anthonym
