fitting facelift AE86 bumpers on to a non facelift
Postby coleman » Mon Sep 06, 2004 2:55 pm
is there any difference between the mounts?
or can i straight swap with no or little effort?
coleman
Postby coleman » Mon Sep 06, 2004 5:35 pm
also ages ago i tried removing the rear bumper off but had no luck, where are all the points to undo bolts??
i saw there are a few bolts beside where the jack is kept, is that one?
coleman
Postby gdsup » Mon Sep 06, 2004 6:33 pm
to rubber bungs over each chassis rail
gdsup
Postby spencer » Tue Sep 07, 2004 10:33 am
i fthe facelift bumpers have the facelift brackets on them the will bolt up no probs. The rear bumper as said above the main bolts are under rubber things on the chassis rail and there are some bolts on the side like where the jack is kept. Also a screw in the guards at the top of the mud flap I think
ms63 crown
spencer
