copper plugs st165+ae101
Postby mr30% » Mon Sep 06, 2004 10:47 pm
Hi, Thanks in advance I need the denso plug code for copper plugs for a st165, ast185, and ae101
2 x 81 starlets/parts 2 x84 starlets ee82 ae82 1 x85 aw11 nz new 1 x84 aw11/parts 1 xae101
mr30%
plugs
Postby mr30% » Thu Sep 09, 2004 10:23 pm
Heeps of posts and web sites say to use copper plugs in st165/st185 ,insteed of plat/ird but nobody says which plug, some body must f@#$ing well know
mr30%
Postby B1NZ » Thu Sep 09, 2004 10:44 pm
For memory the recommended plugs for an AE101 20valve are Bkr6ep-11 ,take the "p" out of the code and you have the copper equivilent i think??
ps. That previous code is for NGK plugs
Denso part number is: PK20R11
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Twolitre » Thu Sep 09, 2004 11:30 pm
St185 = K20PR-U
AE101 = K20PR-U11
The only difference in the plugs above being the gap, as for ST165, they use a marinally hotter plug than an ST185 although you may as well just use the same plug as the ST185 as a slightly hotter plug wont do you any harm.
I bought BCPR5EY-11 for my ST165 and the ND cross refferenced part no. for that plug is Q16PR-U11
Hope that helps
Twolitre
Postby ROBODISCO_20v » Sat Sep 11, 2004 5:13 pm
B1NZ wrote:For memory the recommended plugs for an AE101 20valve are Bkr6ep-11 ,take the "p" out of the code and you have the copper equivilent i think??
No you have to ad an "S" if you want copper, BKR6ES11 would be the correct part number.
What engine is in the st165 & 185??? If its a 3SGE they'll use something like BCPR5EP8
ROBODISCO_20v
