noisy dizzy - silvertop
Postby strap-on » Thu Sep 09, 2004 10:48 pm
ok well i went all out to fix my leaking plenum chamber, whichwas atributing to the whirring sound comming from under my hood, and its much betetr now, ( not to mention better throttle response so i must have had a leak or two)
neways the whiring noise is now my dizzy is this anythignt o be worried bout cos the car hasnt always done it, does it need a new one or should i just pull the old one apart and give it a good clean?
its just all these random sounds are starting to annoy the bejesus out of me ( im also gonna get a new vvt pully when i can afford)
strap-on
Postby strap-on » Fri Sep 10, 2004 10:36 am
cmon, someone must know something about this
strap-on
Postby RunningRich » Fri Sep 10, 2004 11:15 am
If it is similar to a 3S-GE one you can probably just replace the bearing and seal.
Check this out:
http://gtfour.supras.org.nz/sw20%20distributor.htm
Richard
RunningRich
Postby strap-on » Fri Sep 10, 2004 11:28 am
cheers man sounds like a bearing aye, i will just wait and see if anyone knows anything bout my one first
strap-on
Postby spencer » Sun Sep 12, 2004 11:41 am
Just had one of my 20v dizzys appart bearing was stuffed cost me $8 for a new one
ms63 crown
spencer
Postby strap-on » Sun Sep 12, 2004 12:45 pm
did it make a strange whirring sound? any advice on pulling it apart?
strap-on
Postby spencer » Sun Sep 12, 2004 2:21 pm
na I was doing another dizzy conversion so you can mount the dizzy on the front off the exhaust cam gear for use in a ae8*. When you do this you gotta replace the brass bush on the front with a bearing while doing this I noticed the other bearing was stuffed aswell so I replaced it it made no noise. But this bearing will probly be your problem its pretty straight forward to replace just pull your dizzy appart and have a look
ms63 crown
spencer
Postby strap-on » Sun Sep 12, 2004 2:24 pm
is it much the same as pulling aprt the 3sgte one as described in the link above?
strap-on
Postby spencer » Sun Sep 12, 2004 4:42 pm
yip very similar
ms63 crown
spencer
