AE86 TRUENO : High Beam not working!!
Postby mister_two » Sun Sep 12, 2004 9:43 pm
any guesses?
not the bulbs cuz i just replaced a new one, might be the fuse or relays
but dunno where it is?? :oops:
btw two of em not working on high beam mode..
mister_two
Postby NZ_AE86 » Sun Sep 12, 2004 9:45 pm
Hey, What do you need to know? I can scan it and E-mail it to you if that helps??
NZ_AE86
Postby mister_two » Sun Sep 12, 2004 10:35 pm
It may sound silly but I just wanted to know how to replace the bulb in my headlight without destroying them.
cuz u know they are popup lights kinda different from the other cars i have... :oops: :oops:
cheers bro
email: mister_two88@yahoo.com
mister_two
Postby ~SlideWays~ » Mon Sep 13, 2004 2:22 pm
just pop them up and all u need is a screw driver.
- take the plastic cover off that surrounds the light (2 or 3 screws each side)
- unscrew the chrome frame that holds the glass in
- pull the whole thing out, unplug it at the back
- now with the glass inclosure out, pull the rubber cover off the back
- under the rubber cover is a metal ring that you turn until it lines up with the slots then pull it off
- the bulb should be loose now
- put new bulb in, without touching the glass.
- now do all that backwards
lol its just one of those jobs where you just keep pulling stuff off till you figure it out. Its really easy man.
~SlideWays~
Postby ~SlideWays~ » Mon Sep 13, 2004 2:24 pm
btw heres a scanned ae86 manual online:
http://www.hachilife.com/garage/?manual=cover
~SlideWays~
Postby mister_two » Mon Sep 13, 2004 9:24 pm
Hey cheers Slideways!! :D
I thought it was from the inside out... :oops:
thanks again for the manual!
mister_two
Postby mister_two » Wed Sep 15, 2004 12:43 am
high beam still not working!! any ideas??
mister_two
Postby kingcorolla » Wed Sep 15, 2004 2:07 am
prob just an earth lead from the bulb, if all ure other lights are working, and its not the bulb... check the earth leads.
sometimes the plug contacts are screwed with corrosion and shitt too, dont know if its common on AE86's tho..
1983 Carina AA63 4age
kingcorolla
Postby mister_two » Wed Sep 15, 2004 10:17 pm
I'll try that thanks :)
mister_two
Postby mister_two » Sat Sep 18, 2004 9:17 pm
still not working :(
mister_two
Postby kingcorolla » Sat Sep 18, 2004 11:55 pm
does it flash, as well as high beam, coz thers two switches, check the switch on the steering column.. if u know how to use a multimeter..
its best if u think of it as just a basic curcuit, coz thats what it is, a power source, a switch(es), RELAY, bulb, ground.
kingcorolla
Postby mister_two » Sun Sep 19, 2004 7:45 pm
I don't really know how to use the multimeter,
but the flash nor the high beam ain't working
maybe the switch, is that in the dash board?
what do i do now :oops:
mister_two
Postby kingcorolla » Sun Sep 19, 2004 10:52 pm
u know how to use a testlight? just earth the clip and prod, if the light comes on, therz current at that curcuit, just give it a prod around, see were u can find power, and if u find no current in one curcuit, trace it to were the break is, coz its parrallel curcuit, not all lights will fail if one does.
hope this helps 8)
kingcorolla
Users browsing this forum: Google [Bot] and 27 guests
