AE101 mufflers
AE101 mufflers
Postby B_giB » Mon Sep 13, 2004 11:08 pm
I was looking at the mufflers on my AE101, and noticed one muffler was bigger than the other...
is this normal, or is my levin ad-normal???
Current: SXE10 Altezza
Previous:AE86 Trueno Notch Back: Gone but not forgotten :cry: :(
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Postby aesc » Mon Sep 13, 2004 11:26 pm
Yip its normal. The one on the RH side is bigger, dont know why
EX AE101 owner
2013 Ford Focus ST
aesc
Postby kingcorolla » Tue Sep 14, 2004 12:54 am
-some people say- that havving to mufflers, one to control back pressure, only when needed, when there is no load on the engine, only one functions..?
1983 Carina AA63 4age
kingcorolla
Postby Sanxta » Tue Sep 14, 2004 1:52 pm
the one on the left is for cosmetics in balancing uop the rear look of the car - the "sports" look :roll:
the right hand muffler is larger because it primarily takes the exhaust flow, but if your revving higher then the left hand one will come into use aswell
Sanxta
Postby Mr Revhead » Tue Sep 14, 2004 2:48 pm
iv often been stopped behind ae101s and noticed gases coming from only one side, but iv seen them do it from either side! but then again cant tell if the exhaust is stock. i know looking at the mufflers on mine i shudder everytime i see the gasses entering at 90 deg to the muffler!
Postby Sanxta » Tue Sep 14, 2004 2:52 pm
mmm . . . a very inefficient standards system. maybe it was to elliminate exhaust rasp from the 20 valve? an exhaust fitter was telling me somewthing about that . . .
Sanxta
Postby JT » Tue Sep 14, 2004 2:59 pm
Sanxta wrote:the one on the left is for cosmetics in balancing uop the rear look of the car - the "sports" look :roll:
Yeah, above ~3K rpm there is enough flow to push the valve in the Y join open for the left muffler.
JT
Postby Mr Revhead » Tue Sep 14, 2004 3:04 pm
well it didnt work!!
theres a valve?? are you sure? iv seen other toyota with a valve (supra) but they have an actuator system visable fron the out side, nothin like that on an ae101. i guess its spring loaded. have you seen this or been told?
Postby JT » Tue Sep 14, 2004 5:58 pm
No, you can't quite see the join when you take the left muffler off and wasn't too keen on cutting the exhaust system up. Im pretty sure there is a valve and yeah spring loaded would seem logical. Has any one cut theirs up before?
JT
Postby Andy from the block » Tue Sep 14, 2004 6:43 pm
My car has a twin sports muffler system from japan and they both flow the same as far as I can tell right from idle.
not sure about the standard system tho.
Andy from the block
Postby Dr-X » Tue Sep 14, 2004 7:13 pm
No, there is no valve. The twin mufflers a purely cosmetic.
Dr-X
Postby strap-on » Tue Sep 14, 2004 11:06 pm
Dr-X wrote:No, there is no valve. The twin mufflers a purely cosmetic.
frankly im getting quite sick of you, have u ever cut one up?
i might go have a decent llok at my old ones that are sitting in the sheed and have a look, truth be told you are probably rite..... but u dont know that for sure do you?
strap-on
Postby Silent Knight » Wed Sep 15, 2004 2:07 am
according to what i know and have heard i'm pretty sure there is a valve in there :?
Silent Knight
Postby AceSniper » Wed Sep 15, 2004 7:07 pm
I thought that the size of the mufflers is what controlled the flow of them with the 2nd one been smaller and more restricted.... iv hurd that the blacktop muffler has a spring gate/valve init to flow more in higher revs doing the same thing as the two mufflers on the silvertop but I dono anyone who can say its true.
AceSniper
