Silent Knight wrote:if it's a rattle at a certain RPM range it could be an engine mount that's semi or fully f****d![]()
hve you tried standing in front of the motor and revving it up to see how far it tilts over?
SKDABL wrote:Yah the engine mooves like 2cm
What should I do about it?
It only rattles once it gets back down to idle
SKDABL wrote:Could the engine fall out as i drive along?
low_rider wrote:BRING BACK COMMUNAL SHOWERS!!!!!!!!!!!!!
low_rider wrote:SKDABL wrote:Could the engine fall out as i drive along?
SKDABL wrote:low_rider wrote:SKDABL wrote:Could the engine fall out as i drive along?
Just making sure lol
I checked underthe bay for the rattle and i cant seem to find where its comming from, all mounts look fine, rattles not comming from mounts, its definatly under the engine, near the extractors and the beginning of the exhuast.
Should I get this checked out? or isn't it that biga deal?
Thanks.
Tim
10k 20v wrote:as for the hesitation there are some valves in the intake maifold and if the diaphram for the acuators split can cause a surge. same with the vaccum advance on the dist.
