Uneven Acceleration
Uneven Acceleration
Postby Just_Juzz » Fri Sep 24, 2004 8:40 am
My car has been worrying me a little as of late.
When accelerating the revs seem to get high, then drop down again, then climb again.
Sometimes the revs seem to stay constant, but the car keeps accelerating.
I have no idea what it could be, throttle not opening properly?
Any thoughts?
Current Ride: 1998 Caldina GT
Me, me, me, me.....
Just_Juzz
Postby Helious » Fri Sep 24, 2004 8:42 am
sounds like your clutch is slipping?
Helious
Postby Just_Juzz » Fri Sep 24, 2004 8:49 am
Yeah, thats what I was thinking, as the clutch is on it's last legs, but my girlfriends old man is a mechanic, and he said the clutch isn't bad enough to be slippin at the moment....
But I might get him to check it again.
Me, me, me, me.....
Just_Juzz
Re: Uneven Acceleration
Postby Disco » Fri Sep 24, 2004 1:30 pm
Just_Juzz wrote:When accelerating the revs seem to get high, then drop down again, then climb again.
Any thoughts?
How high are we talking? and how mashed into the floor is your pedal?
If the revs stay constant and you're still accellarating, try changing out of 2 and into D. :P
have you checked the plugs recently?
those engines have vvt don't they? I'm not sure...
Disco
Postby CozmoNz » Fri Sep 24, 2004 4:02 pm
um, this isnt being an arsehole, but its not an auto is it?
because automatics concentrate rpm at the max torque... to push the car foward without using more petrol than required....
Rayne For President!
CozmoNz
Postby saft » Fri Sep 24, 2004 4:17 pm
he's already said it has a clutch :roll:
saft
Postby Just_Juzz » Fri Sep 24, 2004 5:27 pm
Yes.... it is a manual.
The plugs are new.
It does it when accelerating from around 2K up.
IE
Put my foot down on the accelerator, in say 3rd or 4th, revs go up to like 4k then drop down again then accelerate up.
Also, accelerating, the revs stay constant, but it accelerates. It is weird.
I thought maybe the throttle isn't opening properly. But cant be sure.
I know the clutch is on the way out.
Me, me, me, me.....
Just_Juzz
Postby Lloyd » Fri Sep 24, 2004 5:57 pm
The revs cant stay the same and have you accelerating. For the gearbox to be turning faster there needs to be something driving it faster (ie the engine) and since they are mechanically linked (bar the clutch) you cant really accelerate with constant engine revs.
I'd be changing the clutch now if its on its last legs and see if you still have the problem
Postby Distrb » Fri Sep 24, 2004 6:10 pm
The plugs are new.
IE
IMHO you should cut out your known issues (i.e. your clutch), because there are cases where they will influence the behaviour of something else.
Distrb
Regular Poster
Postby Just_Juzz » Fri Sep 24, 2004 6:33 pm
Yeah, I am on to that.. clutch kit for $149
A mechanic at work doin it for a perky...
So we'll see what happens after that
Me, me, me, me.....
Just_Juzz
