Still too rich... wtf?
Postby skoty » Fri Sep 24, 2004 9:26 pm
OK the engine is a 4age I fitted recently into my GT. Runs mint, goes fine but still is running too rich, the water temp sensor which determines the richness of the fuel/air mixture was replaced which improved it a lot however still isn't running right? Im outa ideas? :roll: :?
Profile - Cars Owned - AE82 Corolla GT / Corolla Dirt Track Car / N14 Pulsar GTI / S14 Silvia Qs / Nissan Van / Nissan Avenir GT
Current cars - Altezza RS200 and Mitsi Lancer GSR
skoty
Postby kingcorolla » Fri Sep 24, 2004 10:38 pm
what type 4age is it? maybe the O2 sensors buggerd? or check the idle mixture adjustment...
maybe a fault code check could be helpfull
1983 Carina AA63 4age
kingcorolla
running rich
Postby GOLDAE86 » Fri Sep 24, 2004 11:49 pm
Check your fuel pressure, make sure your fuel rail reg is working correctly.
To finish first, first you must finish
GOLDAE86
Real Life Mechanic
Postby skoty » Sat Sep 25, 2004 7:44 pm
Its a NZ new bluetop MAP sensored 4age with no oxy sensor.
skoty
