yobbosayo wrote:I was just wondering, if cold air is so important (pods, airboxes etc) why are my old cars and my bike more powerful when they warm up?
Or is cold air only important for preventing detonation on EFI cars?
riddles wrote:So, dumb question time. How cold is too cold? What if you were to take the air from your airconditioning, (or add a second unit) and feed that to the engine?
Using a aircon unit would be most impractical, not only couldn't it flow enough air to make a difference, the parasitic loss from the aircon unit would cost more that it could gain.
Scotty wrote:Don’t some drag teams run air through a pipe, which has liquid nitrogen around it to get it as cold as possible?
Zak wrote:The only problem with cold air is condensation, as the water condenses and water in a motor is bad
Zak wrote:The only problem with cold air is condensation, as the water condenses and water in a motor is bad :(
JiNX wrote:riddles wrote:So, dumb question time. How cold is too cold? What if you were to take the air from your airconditioning, (or add a second unit) and feed that to the engine?
Basically there's no such thing as too cold, as long as the car is fuelled to cope with it.
Dr-X wrote:BS, dude. The optimal air temperature inside the cylinder, if I remember correctly, is 42C. Once you get to very cold temperatures, and particularly icey temperatures, it makes combustion a lot more difficult.
Using forced induction, temperatures make a bit more difference, but not anywhere close enough to overcome the power loss of an AC system.
fatgtr wrote:slightly off topic but if u are running a pod filter with a cold air box, and u put a air compressor (an electronicly controlled one like u can get at the warehouse for $20) and u put i between the throttle and cold box will that have the same effect as a turbo?
