crank pully removal
crank pully removal
Postby kp_drifta » Tue Sep 28, 2004 11:48 pm
hmm ohk this is gonna sound stupid but im in the process of stipping an FX-GT ready for head removal etc and ive taken all the alternator belts and alternator etc off but i cant seem to unbolt the crank pully without the engine winding over, some one help me please
kp_drifta
Postby Muzzie » Wed Sep 29, 2004 12:02 am
If it's on a stand, flip it over, take the sump off and jam the crankshaft with a screwdriver / steel bar or similar so it won't turn over.
Thats what we did in MIT when we worked on our practice motors (teachers idea).
I figure it's as good a way as any :)
Muzzie
Regular Poster
Re: crank pully removal
Postby matt dunn » Wed Sep 29, 2004 12:03 am
kp_drifta wrote:hmm ohk this is gonna sound stupid but im in the process of stipping an FX-GT ready for head removal etc and ive taken all the alternator belts and alternator etc off but i cant seem to unbolt the crank pully without the engine winding over, some one help me please
put in gear and get someone to hold there foot on the brake while you undo it.
Postby kp_drifta » Wed Sep 29, 2004 12:25 am
hmm yea cheers, kinda disconnected the clutch lines alredi guess ill just jam it in gear :D
kp_drifta
Postby kingcorolla » Wed Sep 29, 2004 12:47 am
when i pulled the crank pulley of my bluetop,(on a stand) i couldnt get the cambelt pulley (behind the main pulley) off the crank, my keyway & crank front end was fukkd. I even posted a TOPIC on how to get it off! :x untill i brought a puller.. then i had to replace crank 8O ...then i found out my BLUETOP had incorrect internals 8O ..so i had to buy rods to match crank 8O ...as well the pistons to fit the rods etc etc...
just some of the things u run into when rebuilding an engine... 8)
(ive got heaps of pics, if u got any questions)
1983 Carina AA63 4age
kingcorolla
Postby matt dunn » Wed Sep 29, 2004 12:52 am
kp_drifta wrote:hmm yea cheers, kinda disconnected the clutch lines alredi guess ill just jam it in gear :D
with the engine not running it should still go into gear.
Otherwise get them to hold a little pressure on the gear lever while you turn the crank and it'll pop in.
Postby kp_drifta » Wed Sep 29, 2004 2:32 pm
cheers guys im gunna go and get the c**t off in a few mins
kp_drifta
Postby kp_drifta » Wed Sep 29, 2004 4:12 pm
hmm yea well, i got it all locked up in shit but the $&#$% just doesnt seem to wanna move, even with a nice big strong bar, mayb try a rattle gun?
kp_drifta
Postby Lloyd » Wed Sep 29, 2004 4:34 pm
Rattle gun if you can get it in there. Either that or a strong arm and appropriate socket put firmly in place and crank the engine over. Remember the engine goes clockwise (so get the strong arm somewhere where it wont just jump off, and so it wont spin around before it comes up against something), dont crank it for ages just have it on start for a brief moment, enough to turn the engine over. Rattle gun is preferable, but turning it over with the starter is fine if you cant get at it.
Postby kp_drifta » Wed Sep 29, 2004 4:39 pm
looks like in gunna hav to go get the little compressor from dads wrk, the car has no ignition and shit like tht the manufolds etc r off too
kp_drifta
Postby pc » Wed Sep 29, 2004 6:09 pm
If you take the starter motor off and jam a big screwdriver in the teeth on the flywheel and brace that against the side of the hole that the starter motor came out of, that should do it. I've done it a couple of times like that.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby sopachrga » Wed Sep 29, 2004 11:03 pm
Yeah, rattle gun is definatly the way to go....
After trying everything I could think of that was the only way we could do it.
Speaking of Crank pullies, does any one have a 12 or 14 psi pully for a SC 4agze for sale.....
if so please let me know!!!!! :lol:
sopachrga
Postby krad » Thu Sep 30, 2004 6:25 pm
If the engine was still in the car you could brace a rachet or something up against the chasis then using the starter motor (rm main coil so it dosn't start!) crank it until it comes off. This will take almost anything off from what I've heard. Worked for me.
Just don't do this with a Honda, you will tighten it even more :P
krad
