Tein Springs
Tein Springs
Postby nobbie » Wed Sep 29, 2004 12:55 pm
Hi,
Just wondering something here...
Did tein ever make springs that you can use without a coil over kit? or do all tein springs have to be used in conjunction with a coil over set up. As I understand the size of a coilover and standard spring are different?
Thanks
nobbie
Postby slithr » Wed Sep 29, 2004 6:56 pm
Yeah they make normal lowering springs for use with standard shocks
slithr
Postby THA SHZ » Fri Oct 01, 2004 9:44 am
Yeah u can get them off me if you like , but wot type of car do u have as they don't have a huge range its generally from about 94 onwards.
Also if ur after low as u can go then these aren't your springs but ifu want truelly good handling than these are ur springs . :D
THA SHZ
Users browsing this forum: Bing [Bot], Google [Bot] and 16 guests
