wot the hang ?????????
Postby shaggz » Fri Oct 01, 2004 4:00 pm
hey you'll i gots my self a 99 rolla wagon and wanna wack a pod filter in buts got a problem its got a funny sensor of sumsorts that goes into the filter box wot is it and can i jst leave it dangling>??????????
drive it till it breaks, then upgrade it
Santa Edit: Steve is the former owner of a man-card
shaggz
Postby Zak » Fri Oct 01, 2004 5:13 pm
Is it black and kinda pointy? I had on in my FX-GT and just left it dangling, so it might be ok.
Zak
Postby Adamal » Fri Oct 01, 2004 5:15 pm
Air temp sensor
Postby ROBODISCO_20v » Sat Oct 02, 2004 2:10 pm
YES Air Temp Sensoir. with summer coming on you'll want to be plumbing it back in to the intake pipe. Try putting it as close to the throttle body as possible. It sensors the air temp and send the signial to the ECU. with this info the ECU determins the amount of fuel its going to deliver into the engine. so it is quite important
ROBODISCO_20v
Postby Lloyd » Sat Oct 02, 2004 2:32 pm
Although in saying that its just a trimming kinda thing. Engine doesn't so much rely on the sensor for how much air the engine is using, just to fine tune the signal its getting from MAP/AFM. If its there you should probably have it in though
Postby Dr-X » Sun Oct 03, 2004 10:32 am
I knock mine out (1995 carina ED, 3sfe) when i was doing some work, and didnt notice for a few weeks. didnt seem to make any difference at all.
Dr-X
Users browsing this forum: No registered users and 29 guests
