turboing a k series...
Postby mr bmw » Mon Oct 04, 2004 1:00 pm
rit-e-o
after a few other plans hav been taken off the drawing board, i have decided to turbo a 5k carb to go in my starlet.
now im wanting a basic set up just to give it a bit more go juice.
how much effort is this going to involve
ie. what type of turbo, how much internal work am i going to need to do, where will i get the manifold etc etc etc
cheers for any help
mike
APPARENTLY, THE WORD "NON-FLAMMABLE" IS NOT MEANT AS A CHALLENGE TO ME... HUH, LEARN SOMETHING NEW EVERYDAY!
mr bmw
Postby Rollux » Mon Oct 04, 2004 1:05 pm
Easiest way is a suck thru setup and about 5-6psi. And don't forget to change the jets in the carb to cope.
2002 Allex RS180 6 Speed
Racing a Honda is like competing in the Special Olympics. Even if you win, you are still a Retard.
Nissan Motorsport = Nismo
Honda Motorsport = Homo??
Oversteer is when the Passenger is scared. Understeer is when the Driver is scared
Rollux
Postby RS13 » Mon Oct 04, 2004 2:14 pm
I've been in a 4K turbo starlet, its reasonably nippy, but still nothing flash. I believe a n/a worked 4K would be faster, but less driveable.
From memory, you're looking at custom exhaust manifold, he had a T2 turbo (off an ET turbo pulsar), and an SU carb off an older euro something(Vauxhall?). Didn't idle too well, but went hard, I remember he had issues keeping it cool with the factory radiator, something to take into consideration. And blowing headgaskets on a weekly basis!
Driveline.. it was a 5spd, factory diff. Held up fine.
Hope that helps.
RS13
Postby YeMs » Mon Oct 04, 2004 7:08 pm
im considering doing the same thing. im looking at building a turbo 5k to chuck in an old starlet for a thrash/rally car
looking at a set of solex carbs, and using the ct20 i have spare. will have to fabricate custom manifolds etc for it
Your local Hybrid Elite tech
YeMs
Postby Lloyd » Mon Oct 04, 2004 7:15 pm
Cant have an intercooler on suck through, but you need a sealed carby for blow through. IC might not bother you, would probably be an easier way to go. I've got a mate setting up a turbo 5k to drop into a KE20, bits still being cleaned up, balanced etc. Plan is to run a TD04, looks like not a bad size for the engine. Depends how high you want to rev it, where you want your power and everything else as far as what turbo you put on it
Postby matt dunn » Mon Oct 04, 2004 7:51 pm
If you want some low compression pistons and stronger rods use the 1GGTE piston and rods as they fit straight in with no mods required.
When we did it years ago we had to build a sealed box to hold the carb in and keep it pressurised as it kept blowing the seals out of the carb.
Matt
Postby mr bmw » Tue Oct 05, 2004 8:14 pm
just watched a video i made at the tauranga burnouts a lil while ago and there is a turbo 2k? starlet with a nice big intercooler hanging out the front and from the looks he DEFINATLY had over heating problems!!!!!
it seemed to have a box type of thing on top of the carb???
i am really confused now!
mite sit in the corner and cry for a while until i forget everything and start thinking again. :oops: :oops: :cry:
anymore info would be really really helpful!!
mike
mr bmw
Postby YeMs » Tue Oct 05, 2004 9:06 pm
mr bmw wrote:just watched a video i made at the tauranga burnouts a lil while ago and there is a turbo 2k? starlet with a nice big intercooler hanging out the front and from the looks he DEFINATLY had over heating problems!!!!!
mike
well intercooler would mean it would have been blow through, therefore th box could have been like a plenum sort of? say if he had twin carbs, it could have evenly distributed the air through both. and a 2k? why would he bother wen everything would b a straight bolt onto a 4k or a 5k.. or even a 7k?
YeMs
Postby dattohoe » Tue Oct 05, 2004 9:12 pm
thinking of doing this myself whats the deal with the box around the carb? is it just on entry into the carb? or are there other seals that will blow out the sides of the carb say?
dattohoe
Postby kingcorolla » Tue Oct 05, 2004 9:38 pm
one thing i dont get, is the blow through setup, i initially thought this was not possible.
Reason being, I thought as soon as there is above atmosspheric ( boost) through the carb, it totally contradicts the carbs function. Meaning causing a high pressure eliminates venturi effect, therefore no fuel..? Because its LOW pressure which draws the fuel?
grrr i need to know!
but a "suck through" is completely understandable :)
1983 Carina AA63 4age
kingcorolla
Postby Lloyd » Tue Oct 05, 2004 9:51 pm
.....rising rate......
Postby YeMs » Wed Oct 06, 2004 7:57 pm
HRT wrote:.....rising rate......
i am assuming u mean rising rate pressure regulator? how is it possible, considering carbs use a fuel bowl, which are $&#$% all pressure. i have seen carburetor'd cars using a fuel pressure regulator, but its not a rising rate type.
YeMs
Postby mr bmw » Wed Oct 06, 2004 10:52 pm
well intercooler would mean it would have been blow through, therefore th box could have been like a plenum sort of? say if he had twin carbs, it could have evenly distributed the air through both. and a 2k? why would he bother wen everything would b a straight bolt onto a 4k or a 5k.. or even a 7k?[/quote]
ok... confused/excited at the same time.....*giggles like excited child*
7K tehehehehe please explain more....... hav noever heard of these things..... how many cc, how much, where from?????
cheers mike
mr bmw
Postby wde_bdy » Wed Oct 06, 2004 11:01 pm
Good luck finding a 7k, and if you do its not likely to be cheap. Came in late model vans in carb and efi form from 97-98. 1800cc but not a very revvy motor due to the longer stroke and presumably a taller deck height to match.
Callum
wde_bdy
Postby mr bmw » Wed Oct 06, 2004 11:15 pm
solves all problems then.
4 or 5k it is!!!
still considering making a hellishly high revving n/a just for easier insurance!!
mr bmw
Users browsing this forum: Bing [Bot] and 24 guests
