clutch or gearbox?
clutch or gearbox?
Postby Voodoo » Thu Oct 07, 2004 9:12 pm
hey, i recently got a new clutch (bass button i think) shudders if u ride clutch,
anyway im finding that its getting hard to change into gears (especially when cold) mainly first,reverse, and changing down to third,
now when i push clutch in its pretty much at the floor before it engages and quite often makes a small whining sound as a change into gears as if clutch is maybe not totally engage? can anyone shead some light, is my gearbox getting shaged or could it be something to do with clutch?
Voodoo
Postby pc » Fri Oct 08, 2004 9:34 am
try bleeding the clutch fluid. there might be air in the lines which means you have to push the peddle in further to dis-engage the clutch... or it may not even dis-engage properly.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Voodoo » Fri Oct 08, 2004 4:36 pm
cheers, ill try that
Voodoo
Postby 4ageturbs » Fri Oct 08, 2004 5:48 pm
u aint realy suposed to ride them mine lastd 5000k and a puk snapd off
4ageturbs
Postby Monsterbishi » Fri Oct 08, 2004 6:43 pm
4ageturbs wrote:u aint realy suposed to ride them mine lastd 5000k and a puk snapd off
Then you got sold a crap clutch, when you ride a button clutch it just wears exceeding quickly.
Voodoo, before you go bleeding the system, try adding a half turn or two onto the master cylinder rod length, the new clutch will probably have a lot more meat on it that your old one so will need more travel on the pressure plate to disengage it fully.
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby jjd » Fri Oct 08, 2004 10:40 pm
Did you get your flywheel skimed?.If you did you need to know how much was taken off and add a washer of same size under the clutch fork pivit to compensate.
jjd
Postby Voodoo » Fri Oct 08, 2004 11:19 pm
yeah, i relise that, the suddering kinda puts ya off doing it, just sometimes abit hard launching it through a drive through etc :?
and thanks for the info Jinx and jjd
Voodoo
Users browsing this forum: No registered users and 76 guests
