Drivetrain
Drivetrain
Postby CAMB01 » Mon Oct 11, 2004 6:44 pm
This is probably something you've heard before but, will AE101 4AGZE LSD driveshafts go into an AE92 with the AE101 gearbox?
If not will AE92 4AGZE driveshafts go into the AE101 gearbox?
any information concerning these questions will be great.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
DRIVE SHAFTS
Postby GOLDAE86 » Mon Oct 11, 2004 7:11 pm
By memory i dont think they do.The gze axles are alot thicker than the AE101 axles.But i said by memory so ????
To finish first, first you must finish
GOLDAE86
Real Life Mechanic
Drivetrain
Postby CAMB01 » Mon Oct 11, 2004 7:48 pm
The AE101 gearbox is LSD not a standard box.
I know the mounts are all the same just want to know what driveshafts i can use.
CAMB01
Postby CAMB01 » Tue Oct 12, 2004 6:21 pm
bump
CAMB01
Postby Monsterbishi » Tue Oct 12, 2004 11:13 pm
The definitive answer is:
"No"
The 4AGZE axles use a entirely different spline setup on the gearbox side of the axles, the only 1600cc boxes they'll go into are 4AGZE ones.
--- Cut Here ---
'94 JDM Ford Mustang GT Coupe
Monsterbishi
Postby Mr Revhead » Wed Oct 13, 2004 11:14 am
hmm a little confusing how you worded your question cam,
gtz axles will only fit gtz boxes, they wont fit non s/c boxes.
non lsd ones are slightly longer than lsd ones, they fit but you have to shorten the spline end. dont know how much though
i think ae92 and ae101 gtz ones are different lengths
Drivetrain
Postby CAMB01 » Wed Oct 13, 2004 10:32 pm
Let me explain what i have and what i want to do:
I have an LSD gearbox and driveshafts from an AE101 4AGZE.
I want to put them in my AE92 Corolla FX-GT along with my engine that i am building.
1. Will the shafts fit?
2. Will AE92 4AGZE LSD driveshafts fit into the LSD gearbox that i have?]
The left hand drive shaft the shorter one that i got (AE101 GZE) doesn't have an outer CV. I have searched around a small bit, and found that you can't buy CV's for them, you have to buy the complete driveshaft, genuine is $946 ex japan.
Would New Zealand CV's be able to help me out with this problem? If the shafts will fit of course.
CAMB01
Postby CAMB01 » Fri Oct 15, 2004 6:01 pm
bump
CAMB01
Postby 2MELT4 » Mon Oct 18, 2004 7:51 pm
Put it on the back of the trailer Cam hehehe :-p jst kiddin Havnt Done your starter yet either my bad we is busy
2MELT4
DRIVETRAIN
Postby GOLDAE86 » Mon Oct 18, 2004 10:18 pm
Give mike at nz cv's a call and give him a spline count of the outer axle end and the hub spline, seal size, and length required, he got some cv's for my car a while ago.If u have no luck drop me a pm and ur cell number and i will find some thing for ya. :)
GOLDAE86
Real Life Mechanic
