LSD FOR STARLET 83
LSD FOR STARLET 83
Postby nissancona » Sun Oct 17, 2004 4:40 pm
Hey does anyone know were i can get an lsd for a starlet made up for the right $ cheers :P
nissancona
Postby z|gen » Sun Oct 17, 2004 7:46 pm
chassis code will help, i think TRD do one, otherwise just ring a few car performance places and see if they can help you out.
AE91 SUPERCHARGED COROLLA
z|gen
Postby kingcorolla » Sun Oct 17, 2004 8:13 pm
z|gen wrote: i think TRD do one,
no they dont, not for a kp
1983 Carina AA63 4age
kingcorolla
Postby wde_bdy » Sun Oct 17, 2004 8:22 pm
If yours is an 83 drop hatch model it SHOULD have a U code diff for which LSD was available. Unfortunately my latest info says it is out of production. There are a few secondhand ones floating around, but they are not cheap. Good luck finding one.
Callum
wde_bdy
Postby Stu- » Sun Oct 17, 2004 8:48 pm
They're not exactly the strongest diff setups. Convert to T series or even better G series. LSD's are more common for those. Big job thou.
Project Thread
Stu-
Postby Mr Revhead » Mon Oct 18, 2004 9:38 am
if any one knows where to get some startlet lsds let me know!! i get asked for them about 4 times a month!!
Postby TRD Man » Mon Oct 18, 2004 2:59 pm
We all do Warwick. We've searched the world for an alternative to the TRD unit. With no luck.
Trouble now is that not only do TRD not produce the 6.0" LSD but they no longer make the repair kit either.
So if you find a 2nd hand item which is a bit worn, you can't buy the clutch pack to beef it up again.
Better option is to look at ways of installing the 6.7" AE86 unit. This will be around for some years to come, as will the repair kit.
TRD Man
Postby Muzzie » Mon Oct 18, 2004 7:53 pm
Just lock the bugger :)
Full drive full time :D
Muzzie
Regular Poster
Postby matt dunn » Mon Oct 18, 2004 8:04 pm
EP71-4age wrote:They're not exactly the strongest diff setups.
Yes. If you have enough power to need a LSD you probably need a stronger diff and axels.
Matt
Postby Dunny » Tue Oct 19, 2004 1:53 pm
Other option is to go to a escort LSD - same width as a Starlet Diff, plenty of parts & ratios avail, 6.5", with abit of fabrication in she goes.
Problem is like most LSD's its not cheap and new is probably the best option being as 2nd hand ones are only about $300-$400 cheaper and could be well worn.
Dunny
