aesc wrote:11psi is not stock, they run 8-9 standard so maybe he has a 164mm pulley on it.
aesc wrote:He could put an SC14 supercharger on it, is a bit of work to make it fit as it has larger displacement, but the results would be good. Im not sure what you mean by 'taking more power to run', the engine would be able to run it sweet as. The sc14 s/c came off an old Soarer, not sure what model though.
aesc wrote:Yip the Cusco ones are the best but are not easy to come by and are expensive ($1600 apparently). evil_si on here makes the 175mm pulleys by modifying the existing crank pulley and are very good, several ppl have bought them and swear by them
aesc wrote:might as well get in first, but I would suggest turboing it if hes keen on getting serious power. The supercharger no matter what you do will not be efficient at higher rpm, the power loss is very noticeable and is backed up by dyno results.
Banga69 wrote:how much has he got to spend? you cna do anything but im sure $$ will play a big part.
Disco wrote:aesc wrote:might as well get in first, but I would suggest turboing it if hes keen on getting serious power. The supercharger no matter what you do will not be efficient at higher rpm, the power loss is very noticeable and is backed up by dyno results.
yeah, thats a given really.. turbo vs charger is always gonna come out turbo on top... really depends on your app.... this is gonna be a round town beater for the most part i'd suggest so charger will be better I think..
thanks aesc, I will await other responses
EVLGTZ wrote:IF ya dont use aftermarket ecu (or some other timing altering device) then that power loss will be there whether its turbo or s/c. Therefore this power loss issue at higher rpms isnt really an issue if the s/c is upgraded AND ecu as well.
IH8TEC wrote:anyone know how much boost they could push, like maxish on sc12 is 14-15psi, what would the sc14 do?
EVLGTZ wrote:
Bazz is helping Fred upgrade the s/c to sc14 on his one at the mo. Although I think hes running afm verison 4agze so he prob wont need to aftermarket ecu to resolve these timing issues. Might be an idea to talk to one of them. Larger s/c is a very cool idea and different from all those jumping on the 4agte bandwagon. Should produce some good results.
gdsup wrote:well now my car is almost running i shall endeavour to dyno in this progression sc12-10psi on standard pulley, sc12-14psi, sc14 with larger pulley (i.e 14psi on sc12 pulley) all on standard ae92 MAP ecu, with the aim of 150 rwkw @ tourque performance on standard head/block/ecu, then prob change to megasquirt ecu, should be interesting to see how it goes...
