4agze wizard wanted.
Postby jacko » Fri Oct 22, 2004 5:02 pm
Ive given up on trying to sort out my surging/stutterring problem on the ae92 - Im pretty sure its fuel related and it only does it intermitantly and only under full gas.
Is anyone out there good at diagnosing problems (possibly ecu related) for coin... or a box ?
lickem.
jacko
Postby FLAWLES » Fri Oct 22, 2004 5:56 pm
going around corners? and hard acceleration???
my 101 gtz does this under 1/2 a tank its to do with the tank and pick up can only be fixed by surge tank and exturnal pump
FLAWLES
Postby jacko » Sat Oct 23, 2004 3:58 pm
You are a $&#$% legend. Problem solved. I owe you a beer, I was about to pull out my ecu :roll:
Is it to do with a dieing fuel pump?????
lickem.
jacko
Postby FLAWLES » Tue Oct 26, 2004 6:00 pm
NAH
just fuel surge ie when fuel goes to one side of the tank and the pump starts to pump air instead of fuel
not much to fix + it looks cool to
surge tank $150
300hp bosch pump $200
plus install who knows
FLAWLES
Postby CAMB01 » Wed Oct 27, 2004 7:23 pm
Problem with that answer is that the fuel tanks have baffles in them so the pump is always supplied with fuel.
1993 Mitsubishi EVO 1 Racecar
1989 AE91 FX-ZS (Previous)
Custom Works Automotive
http://www.HCCC.org.nz
CAMB01
Postby Lloyd » Wed Oct 27, 2004 7:32 pm
FLAWLES wrote:my 101 gtz does this under 1/2 a tank its to do with the tank and pick up can only be fixed by surge tank and exturnal pump
My AE92 does this also
Postby jacko » Thu Oct 28, 2004 4:59 pm
Seems strange that my virtually factory car does it, design fault by toyota?
lickem.
jacko
Postby FLAWLES » Thu Oct 28, 2004 5:24 pm
CAMB01 wrote:Problem with that answer is that the fuel tanks have baffles in them so the pump is always supplied with fuel.
HA WOTS THE PROB WITH THIS???????????
the baffels are there to stop surge and keep the pump flowing the gtz have a " problem " with this and below 1/2 tank it starts to starve under hard eccl and right hand cnrs
the only way i can see how u can fix this is surge tank with a external pump
FLAWLES
Postby Me_19588 » Thu Oct 28, 2004 6:16 pm
Easy and cheap just keep more than half a tank of gas in your car
Me_19588
