better fuel
better fuel
Postby dskd » Wed Oct 27, 2004 8:54 pm
what do ppl run / add to fuel to run more boost and not get detanation
dskd
Postby atmosports » Wed Oct 27, 2004 9:19 pm
Avgas or any of the competition fuels is a good start. You can always add some Toluene to those if need be. Else you could always try water or water/methanol injection but I've generally found your wasting your time unless you buy an Aquamist or similar top end setup as most setup's act like a steam cleaner & do bugger all.
atmosports
Postby Leon » Wed Oct 27, 2004 9:21 pm
avgas + o2 sensor = bad
Postby wde_bdy » Wed Oct 27, 2004 9:47 pm
Leon wrote:avgas + o2 sensor = bad
Not to mention a big nasty fine if its not a motorsport car and you use it on the road.
wde_bdy
Postby matt dunn » Wed Oct 27, 2004 10:36 pm
so i shouldn't have put the rest of my avgas into the van to tow the car home?? :lol:
Postby wde_bdy » Wed Oct 27, 2004 10:45 pm
matt dunn wrote:so i shouldn't have put the rest of my avgas into the van to tow the car home?? :lol:
You sir are a naughty naught person. :lol:
You're not likely to be picked up for it, but it is better for people to take an informed risk.
Callum
wde_bdy
Postby Adamal » Wed Oct 27, 2004 10:52 pm
I did not know that!
Any reason why?
Postby wde_bdy » Wed Oct 27, 2004 11:02 pm
Avgas is heavily leaded, leaded fuels have been outlawed for road use.
Callum
wde_bdy
Postby dskd » Thu Oct 28, 2004 6:55 am
what can u use that wont stuff o2 senors
dskd
Postby strap-on » Thu Oct 28, 2004 7:54 am
98 with heaps of toulene, then again ur in teh south island, so try 96,
then again isnt 96 essentially 91 with an octane booster? you guys in the south island are so unlucky u dont get 98
strap-on
Postby levin_it_large » Thu Oct 28, 2004 8:25 am
98 with octane booster!!! :P
levin_it_large
Postby blitza » Thu Oct 28, 2004 9:18 am
you are better off putting tolulolene into the lower octane pump gas, as the higher one has so much crap in it to get the octane up. also avgas/race fuel does go off, you can loose 5-15 hp from gas sitting around.
MAD Industries Limited
blitza
Postby dskd » Thu Oct 28, 2004 5:13 pm
whats tolulolene where u get it ?
dskd
Postby FLAWLES » Thu Oct 28, 2004 5:29 pm
at race/ drag events i just run 98 with nulon octane boost
surposedly gos up by 7 numbers not bad stuff tho
FLAWLES
Postby atmosports » Thu Oct 28, 2004 5:35 pm
The main reason avgas/racegas is illegal is the fact there is no road tax on it, & you don't pay road user charge son petrol powered vehicles.
Touelene is essentially paint thinner, you can buy it direct from Mobil etc in 20L containers. Don't spill it on paint, try not to spill it on yourself either as it's pretty nasty stuff & use in a well ventilated area.
I'd start off with a 10% touelene mix & increase upwards, I've yet to see much gains going past 33% touelene even on highly modified turbo's. Touelene does have a habit of attacking rubber seals etc so make sure your fuel lines,pump seals & injetcor orings etc are all in good shape & compatible. Most modern cars should be alright as pump gas contains some touelene.
If you still want better fuel then you'll have to look at specialty fuels like Elf PRF - the stuff all the rally guys have to use, it's designed to allow high boost with no knock & it seems to work well. There is other stuff like c16 & the like that work as good if not better but the prices of these fuels starts at around $3L & go upwards of $20L
atmosports
Postby Lloyd » Thu Oct 28, 2004 6:03 pm
atmosports wrote: try not to spill it on yourself either as it's pretty nasty stuff & use in a well ventilated area.
Suspected to cause cancer and also makes you sterile... be careful :)
And its "Toluene"
Postby dskd » Thu Oct 28, 2004 6:10 pm
And its "Toluene"
dont like the sound of the sterile part
where u get it down here hrt ?
dskd
Postby sopachrga » Thu Oct 28, 2004 6:23 pm
And its "Toluene"
And what were you doing to get it on your 'no-no' parts to make you sterile. :D
1987 S/C Manual AW11 (SOLD)
I don't have a Toyota anymore~!
sopachrga
Postby Al » Thu Oct 28, 2004 6:24 pm
FLAWLES wrote:at race/ drag events i just run 98 with nulon octane boost
yep it will go up from 98- 98.7
you need litres and litres of the octane boosters main ingredient, tolulene for it to raise it any significant amount, not a 500ml or so bottle
Al
Postby blitza » Fri Oct 29, 2004 9:34 am
And its "Toluene"
ist also one of the 't's in TNT, and as for sterility, is you rub 10ml on your ballsac you will be sterile for three days......
blitza
