AE85 swapping power steer rack to non-power steer
Postby AE85coupe » Thu Oct 28, 2004 3:11 pm
obviously i will need a non-power steer rack, but what else will i need to do this?
AE85 Trueno *For sale*
Details of car here
AE85coupe
Postby Mr Revhead » Thu Oct 28, 2004 3:58 pm
the arms on top of the knuckles are different, dont let anyone talk you into changing them, the powersteer ones are slightly shorter giving you a quiker lock. if you fit non powersteer ones you will increase the turns needed lock to lock.
the steering coloum is a diff part number between the two, including the yoke that connects the shaft to the rack so best to check that out as well
Postby coleman » Thu Oct 28, 2004 6:22 pm
why would you want to do this in the first place?
i hate non powersteerring in mine, i miss the huge lock and power steer from my old one
coleman aka TOYODA
coleman
Postby CozmoNz » Thu Oct 28, 2004 6:52 pm
ur keeping the car now? YOU BASTARD MAN.
nah keep it man, just replace ur steering bush with an alloy one :). they do that in silvias for more feedback, not like ae86's are heavy, i mean, with p/s you could turn the wheel with 1 bloody finger.
Rayne For President!
CozmoNz
Postby AE85coupe » Thu Oct 28, 2004 7:42 pm
I have my reasons for wanting non power-steer, i don't need to be told to keep the power steer, please just an answer my question as to what is different would be nice :)
Details of car here
AE85coupe
psteer
Postby ezy10s » Thu Oct 28, 2004 7:45 pm
pretty sure you will need the cross member also- the mounting brackets are different between the power steer and non p/steer.
Member #244
ezy10s
Postby gdsup » Thu Oct 28, 2004 11:30 pm
Mr Revhead wrote:the arms on top of the knuckles are different, dont let anyone talk you into changing them, the powersteer ones are slightly shorter giving you a quiker lock. if you fit non powersteer ones you will increase the turns needed lock to lock.
the shorter arms dont give you quicker lock, but more travel under full lock, and more wheel angle for the same amount of turns on the steering wheel, the rack dictates how many turns to lock, unless you have stopers on the arms/hubs like te71 etc :) no power steer is good if you push the car as alot of the p.s on early toyotas can feel very light and floaty at high speed
gdsup
Postby KinLoud » Fri Oct 29, 2004 8:56 am
With rwd Carinas, power steer vs non power steer... might be the same with AE65/86
It looks like there might be a difference in the length of steering column that comes throught the firewall. I've (temporarily) got a non power steer rack and crossmember in one of my Carina parts cars (removed the power steer rack and crossmember). The splined shaft out of the steering column only just engages the nonpower steer universal joint.
I think this is because the power steer universal joint sits higher due to the valve part of the power steer.
If you can get it at the same time grab the steering column just in case you have this problem later.
Also grab the non powersteer arms - sure they are longer but with the different rack you could get bump steer if the arm geometry if different.
Ken
Hamm
021 408 863
Postby Mr Revhead » Fri Oct 29, 2004 11:10 am
gdsup, your quite correct there. my bad.
kinloud, good point on the bump steer, but i havnt heard of it being a problem, iv sold a few of the powersteer arms to ppl and they havnt commented. then again things like that doesnt bother some ppl!!
Postby JT » Fri Oct 29, 2004 2:25 pm
I have no power steering but Im pretty sure I have a power steer rack :?
She's pretty hard to park but hey, at least I'm getting a workout. If you decide to go non-ps I'd be keen on buying the ps parts off you or let me know whats involved with fitting a non-ps rack! Cheers
JT
Postby nzae86 » Fri Oct 29, 2004 4:41 pm
Yes you will need a non power steer cross member, rack and tie rods as the power steer ones are a bit different in length but not by much.
you will also need a non power steer steering column as well as there is a difference in their length.
I use power steer lower strut arms (steering knuckles) in my race car on my non power steer rack and it does take less turns lock to lock, and I do not have any bump steer issues at all
Your addiction to motorsport can only be cured by poverty!
nzae86
