AE101 Trueno Strange Idling
Postby phat_levin » Thu Oct 28, 2004 6:33 pm
ok, most of the time it idles fine (IMO anyway!) but once shes warmed up, on the odd occassion when the air conditioning is on and i am stationary the revs will drop to 600/700 rpm. turning the airconditioning on and off does alter the revs but they drop down again.
also, if the car is idling and you give it some gas, the revs drop for a split second before going up.
help!!
phat_levin
Postby Sanxta » Thu Oct 28, 2004 9:15 pm
yeah mine used to do that too when i tapped the right pedal.
could be the be fuel filter im told . . .
or try taking out the ECU fuse for 5 mins to reset that comp, that fixed mine right away.
look on ur fuse box, you cant miss it.
Sanxta
Postby phat_levin » Thu Oct 28, 2004 9:19 pm
oh ok i'll give it a try and let you know how it goes, did the fuse thing fix your pedal thing too?
whats the idea of that? does it reset the ecu??
phat_levin
Postby Sanxta » Thu Oct 28, 2004 9:22 pm
if it resets then your whole fuel management system starts afresh as it would be from factory i think.
give it a go and see what happens . . . i havnt driven my levin in about a month and a half so i cant remember if it fixed the pedal thing, but i recall it did?
lemme know what happens
Sanxta
Re: AE101 Trueno Strange Idling
Postby kingcorolla » Thu Oct 28, 2004 9:33 pm
phat_levin wrote:when the air conditioning is on and i am stationary the revs will drop to 600/700 rpm. turning the airconditioning on and off does alter the revs but they drop down again.
this is normal. It will idle up when stationary to compensate the AC pump i believe. 8)
1983 Carina AA63 4age
kingcorolla
Postby phat_levin » Thu Oct 28, 2004 9:35 pm
yea but then they drop to 600/700 while the AC is still on! that isnt normal!
phat_levin
Postby phat_levin » Sun Nov 07, 2004 11:27 pm
Sanxta wrote:if it resets then your whole fuel management system starts afresh as it would be from factory i think.
still same old after resetting ecu, gona check for any error codes one day - is a bit better with the new pod and heatshield tho...idles at around 900 now with AC on not 600.......
phat_levin
Users browsing this forum: No registered users and 33 guests
