Turbo 2-stroke nothing to do with toyotas sorry
Postby Fuct Munkey » Thu Oct 28, 2004 9:49 pm
i am wondering as to the implications of makin a turbo 2-stroke. the object in question is a (dirty lil) honda nifty fifty... just for fun. so out of curiousity does anyone have any ideas on y and y not this would/wouldnt work? and where could i find a turbo small enuff, for preferably dirt cheap... i know its stupid, but ideas are welcome.
Fuct Munkey
Postby B1NZ » Thu Oct 28, 2004 10:25 pm
oh, i know who you are now, didnt you ask me this question about an hour ago at the ports??
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby snwtoy » Thu Oct 28, 2004 10:33 pm
Maybe a turbo off a early 80s charade or honda city would be the business?
There was someone at the speedtech drags day with a turbo quad bike.. maybe track them down? (nzmmc might be the place to ask)
snwtoy
Postby pidge » Thu Oct 28, 2004 10:42 pm
Probably a better sized turbo would be one off one of the suzuki 660cc turbo engines (i.e. a bit smaller) Still needs a lot of puff from the 50cc honda two stroke though....
pidge
Postby RS13 » Thu Oct 28, 2004 11:26 pm
Wouldn't work. Smaller 2 strokes rely on scavenging to work, running pressure would negate all factory flow characteristics, meaning I don't see how it would run. There is a scooter along the same lines in Chch, they nos'd it. Anyway, you'd need a tiiiiiny little turbo, even a 660cc 'zuki turbs would need tens of thousands of RPM to even produce postive atmospheric pressure.
Just nos the $&#$%. Would cost less.
RS13
Postby Leon » Fri Oct 29, 2004 9:13 am
throw it off a cliff.
even cheaper way to get it to go faster ;)
Postby Silent Knight » Fri Oct 29, 2004 1:19 pm
use a CT12 turbo from a 1G they are small as $&#$% :twisted: :twisted:
Silent Knight
Postby Mr Revhead » Fri Oct 29, 2004 1:30 pm
hahaha off a cliff! :lol:
but seriosly i dont know where youd get a turbo that small from.. i know they are out there but finding a real cheap one would be hard...
id seriously consider NOS. or goto a model store and buy some nitro like they use in model cars/planes or both!!!
Postby fivebob » Fri Oct 29, 2004 2:13 pm
Forced induction two strokes only work if they are not reed valve engines, ie piston ported, rotary valve or cams. Not sure what type the nifty fifty is, but even if it were possible the benefits of forced induction are reduced by the pumping losses involved, i.e. the increased crankcase compression needed to be overcome by the piston. Also you'd be constantly taking the turbo apart to clean the carbon build up off it so it would be a PITA to keep running.
Get a chamber and NOS if you want to make it go faster.
Speaking of strange engines....who knows what this engine is and who made it? 8O
Postby Mr Revhead » Fri Oct 29, 2004 2:29 pm
um you did! with photoshop! :lol:
hmm 2 stoke injected 3 cyl... interesting head design
got me stuffed, is it a home built special or a mass produced item?
has it got valve for the exhaust? or ports?
Postby vvega » Fri Oct 29, 2004 3:22 pm
nifty fifty =reed valve
you need a rg susuki rg400/500 (sqaure 4)
some of the older motor bikes have it but most moved to the reed valve as a way to smooth the power output
2 strokes love the nos
i know of nos'ed 500cc rg in chch
absolutly unrideable
and blows up often lol
anyways
that motor looks like it has a valved exhaust
mabee to tri to get away from the bulk of a expansion chanbers
i herd of such a engine 10 years back
never seen one though
v
vvega
Postby Mr Revhead » Fri Oct 29, 2004 3:24 pm
yeah def looks like valve exhausts. other wise its and interesting way to run a crank angle sensor! :lol:
Postby snwtoy » Fri Oct 29, 2004 4:23 pm
Err.. can you say ultra long valve stems?? How on earth would the cam (I assume there's a cam under that red cover) drive vavles with stems that long.. what's the point of the distance between the cam and the bottom of the head???
How can you tell it's 2-stroke just from that pic? I would have thought it 4-stroke because it has a sump and injectors, but I'm no expert.
That motor confuses me :?... reminds me of my daihatsus tho :D
snwtoy
Postby Mr Revhead » Fri Oct 29, 2004 4:26 pm
um pushrods! i have heard of them being used in that layout.
also if you look where the inlet ports are in relation to the plugs, that says 2 stroke to me.
Postby snwtoy » Fri Oct 29, 2004 4:49 pm
Nah, pushrod engines don't need a cam/cambelt do they? Surely pushrods are a series of levers opperated off the crank which open/close valves? Or have I been wrong all this time?
snwtoy
Postby vvega » Fri Oct 29, 2004 6:51 pm
snwtoy wrote:Nah, pushrod engines don't need a cam/cambelt do they? Surely pushrods are a series of levers opperated off the crank which open/close valves? Or have I been wrong all this time?
push rods operate off a cam that is normally located next to the crankshaft
the valves would have to that long at all
but anyways
v
vvega
Postby snwtoy » Fri Oct 29, 2004 7:08 pm
Yeah, so what's this engine? The cam's clearly on top and belt driven. Is it both overhead cam and pushrod then? :?
snwtoy
Postby evil_si » Fri Oct 29, 2004 7:37 pm
that turbo quad is jono's, performance metalworks, and was specifically built to tow docile, cant remember what sort of turbo it uses, but it is tiny, the smallest ive ever seen, i know it came from steve murch, motorsport engineering.
ohh and that quad is fuel injected, running a link ecu
evil_si
Postby malc » Fri Oct 29, 2004 8:28 pm
Yeah, the engine is a two stroke, with the intake being at the bottom,
and the exhaust outlet is just visible up the top under the red cover ( you can see the studs for the exhaust manifold just sticking out).
A two stroke works by taking in the air and gas at the bottom of the stroke and letting out the exhaust at the top of the stroke, its a pretty crap way of making torque to be honest with you, but thats how you can tell its a 2 stroke - because the intake is at the bottom.
This one also has a fancy oil and fuel mixing injection system (which explains the two injectors going into it).
looks like its got quite a long stoke.
The exhaust is valved which explains the cam belt running up to the cover at the top.
Doesn't look like its got pushrods at all, only the cam for the exhaust is driven at the top by the cam belt. The intake valves arent normally operated by cams on two stoke engines, normally have reed valves. The reed valve works by letting the gas air mix into the crankcase, but its a one way valve so the gas cant get back out where it came from.
Yes the valve stems may be long, but not as long as was originally thought, the top of the combustion chamber would be somewhere around the crease where the angled part goes into the vertical part in the head.
The silver piping at the top would be for water cooling i'd imagine.
sorry about the life story but its hard to explain things while keeping it short, as for who makes it or if its mass produced i dont know, but i do know that its bloody well made.
:lol: :wink:
malc
Postby malc » Fri Oct 29, 2004 11:15 pm
Oh, and if its a quad bike its probably got a 4 stroke.
malc
