3S-GTE Starter Motor
Postby Audi » Mon Nov 01, 2004 3:37 pm
Now this shows my total lack of mechanical knowledge but where is it in my ST-185 engine bay?
Dig a hole for the next man and you'll fall in.
Audi
Postby deaf_rattle » Mon Nov 01, 2004 4:24 pm
i cant remember off hand where exactly in the bay it is but it will be attached to the gearbox :wink:
Postby Audi » Mon Nov 01, 2004 4:31 pm
good thing the engine bay is so spacious and uncluttered then! :roll:
Audi
Postby deaf_rattle » Mon Nov 01, 2004 4:34 pm
its not that bad, you could always follow the positive lead from the battery to it? :roll:
Postby Twolitre » Mon Nov 01, 2004 4:49 pm
Under the top radiator hose, remove the battery and intake plumbing to the turbo, move the fusebox out of the way and it's right there, two 14mm bolts holding the sucker in besides the obvious posotive and negative terminals.
Twolitre
Postby Audi » Tue Nov 02, 2004 11:10 am
Sounds like fun!
Audi
Postby BL8KK9T » Tue Nov 02, 2004 6:05 pm
its not hard at all, i did one and i dont remember any problems at all, just remember disconnect the battery else you'll have your guyfawkes day in da enginebay :D
yes officer, our sober driver is right behind us
BL8KK9T
Postby Malcolm » Tue Nov 02, 2004 10:44 pm
Twolitre wrote:Under the top radiator hose, remove the battery and intake plumbing to the turbo, move the fusebox out of the way and it's right there, two 14mm bolts holding the sucker in besides the obvious posotive and negative terminals.
come on ryan, you know better than that! there's no negative terminals on the starter motor :P
Postby Twolitre » Thu Nov 04, 2004 2:15 am
Ok my bad, there's one positive terminal and a plug. :oops:
Twolitre
Postby Spannergal » Thu Nov 04, 2004 9:15 am
it should be close to the flywheel - i'm a bit concerned if it isn't. :lol: but flywheel should be found where the clutch or gearbox join to the engine :)
Spannergal
Postby Dell'Orto » Thu Nov 04, 2004 12:27 pm
You still having issues with it Stu? Is it not engaging, or just being a general intermittent piece of shyte?
