3k into dx?
3k into dx?
Postby Daylen » Thu Nov 04, 2004 7:35 pm
hi. im askin 4 a mate so how well would a 3k out of a ke35 bolt in2 a dx? would he need 2 engineer sum mounts or pretty much straight in? also would you need 2 use the box out of a ke35? response would be much appreciated. cheers
Daylen
Postby kingcorolla » Thu Nov 04, 2004 9:10 pm
...o...k... :roll:
k i wont question this one..
yes a you can down-grade 100cc and fit a 3k from a KE35, into a KE70, why you would want to i wont ask.. but yes it will bolt straight in. you dont need the ke35 box as well, unless there is no box in your ke70.
if you are looking for performance, i suggest you save some time (and humiliation) and just fit the 3k head on the 4k. you will get much better results from that and its a piece of cake.
but if you do fit the 3k in place of the 4k, please send me some pics of that, as i think it would be a good laugh too see someone went through the effort :lol:
1983 Carina AA63 4age
kingcorolla
Postby dohca » Thu Nov 04, 2004 9:50 pm
go the whole way and put a 2k in...
:roll:
or u could do the real thing and find a 4k-e or a 7k
dohca
Postby TygerTung » Thu Nov 04, 2004 11:07 pm
HAHA a 2K, the max speed would be like 80!
Yeah a 3k would bolt straight in, it would be WAY slower though, like as slow as a 2k starlie, which is SLOW....
You cannot use a KE35 box as the shifter comes out in a different place, more foward so you'd have to cut a hole in the tunnel, and it would make it poo to drive.
TygerTung
Postby 92GTApex » Fri Nov 05, 2004 2:22 pm
dohca wrote:go the whole way and put a 2k in...
:roll:
If your going to go to 2k why not go to the original K series motor?
They had them running 10,000rpm when they were racing them a loooooong time ago :wink: :lol:
Logan
Current ride: 92 Levin GT Apex
Current project: 91 Levin GT Apex (Crashed - It wasnt me)
www.area-51.co.nz
www.toyperformance.org.nz
www.lextreme.com
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1731
92GTApex
Postby kingcorolla » Fri Nov 05, 2004 5:44 pm
92GTApex wrote:If your going to go to 2k why not go to the original K series motor?
Logan
actually the K engine is almost 100cc larger than the 2k.
but you probably will never find one anyway.
kingcorolla
Postby 92GTApex » Mon Nov 08, 2004 2:48 pm
Logan
1077cc?
What do you mean never find one? I just have to go out into the garage :wink: 8)
Logan
www.area-51.co.nz
www.lextreme.com
92GTApex
Postby kingcorolla » Mon Nov 08, 2004 5:43 pm
92GTApex wrote:1077cc?
Logan
well there you go. Were did you source it?
i'd like to own one. just for the fact that i have one. :P
kingcorolla
Postby 92GTApex » Tue Nov 09, 2004 10:22 am
kingcorolla wrote:well there you go. Were did you source it?
Thats the same reason that weve got one here, Dad wanted to have "Just in case" :wink:
Not sure where it was sourced from, but Dad was with Toyota for 30years so he had a few contacts around the place
Logan
www.area-51.co.nz
www.lextreme.com
92GTApex
