ECU normal?
ECU normal?
Postby Andy from the block » Fri Nov 05, 2004 1:09 pm
I had a problem with me AE101 GTZ where after the engine was warmed up it would sometimes stall and sometimes instead of stalling the engine went into a 'safe' mode (so im told) where the engine had almost no power (ie : codnt even go 40kmh up a slight hill). We tried to get the error codes from the ECU and it didnt work , we thought the ECU was faulty and I bought a another ECU from Mr Revhead. Since then everything worked fine...
Until now.
Recently the problem has come back, sometimes It takes 4-5 starts to start the engine, sometimes when driving normally it wod go into the 'safe' mode with the engine light on, and I wod have to pull over, but usually the problem fixed itself after I turned the car off for about 4-5 minutes the car went back to normal driving.
Today I checked the Error Codes from the Diagnostics box and it came up with the repeatedly flashing light at around 4 flashes a second with NO intervals. Looking at http://www.club4ag.com/faq%20and%20tech_pages/ECU%20Diagnostic%20Codes.htm it says this is when things are in 'normal operation' ???.
Did the ECU not record/remember the fault?
Whats going on?
Anyone got any ideas?
Andy from the block
Postby AceSniper » Fri Nov 05, 2004 4:03 pm
take the top off the ecu and check any capacitors you can see, look around the base were they attach to the board an make sure non are leaking... ifso solder in some new ones... semi sounds like what happend to me
AceSniper
Postby Mr Revhead » Fri Nov 05, 2004 4:13 pm
dude... your avatar... thought i was passing out from the heat!!
ok when did u buy from me? must have been a whiel ago..
do as ace says, (if u feel confident) other wise take the ecu into a sparky.
if tis ok then id suggest taking it into toyota and geting it plugged into thier diagnostics as the next step
Postby Andy from the block » Fri Nov 05, 2004 9:03 pm
Yeah its running fine normally, jst sometimes it plays up :(
I bought the ECU from you about 3 months ago I think.
What are the chances of my car having 2 faulty ECUs one after the other?
could it be something else appart from the ECU causing any of this? maybe wiring? sensors? ??
Andy from the block
Postby AceSniper » Sun Nov 07, 2004 12:15 pm
find the fule relay an pull the top off an spray some contact cleaner in there, and any other plugs that you can easly pull apart... worth a try
AceSniper
Postby Mr Revhead » Mon Nov 08, 2004 9:38 am
hmm less vodka for me i think :roll:
its possible..... but it could also be any of those other things... hard to say from a distance. try aces advice
Postby Andy from the block » Mon Nov 08, 2004 2:56 pm
Yeah I'l give aces advice a go when I got some free time.
Thnx for the advice guys.
Andy from the block
Postby event2 » Tue Nov 09, 2004 10:35 pm
toyota ecu's dont give problems. mitsi ones do. get ya car hooked up 2 a scanner and checked out by a auto sparky.
1991 gtz trueno "HELL YEA" 4 sale (sold and i miss it so)
event2
Postby Andy from the block » Tue Nov 09, 2004 10:41 pm
yeah I'l give that ago when I take my car to a mechanic tomorow.
Thanx for the advice.
Andy from the block
Postby Andy from the block » Wed Nov 10, 2004 8:35 am
Hey Ive noticed my grounding wire from engine to engine bay looks pretty munted, the plastic conector is semi melted.
Could bad grounding be causing the ECU not to record the fault? or even contribute to the problems?
Andy from the block
