3SGE questions
3SGE questions
Postby Caveman » Tue Nov 09, 2004 2:37 pm
My car feels a little flat for what it is. Im running a gen1 3sge with TVIS intake ports and not major mods. I've just been out and theres a hill I like to test on which is about 150m long and quite steep. I drive from the bottom to the top and see how fast im doing at the top. The results
My mums 5afe corolla 4 door manual (rated 80kw): 70kmh
My GTR celica auto :oops: (rated 120kw): 75kmh
My dad recons the injectors could be screwed. Im thinking of replacing them but don't want to if i dont have to.
Were going to take apart the head over the christmas holidays to do a valve grind and polish (i've been told not to port a big port). I'm thinking of replacing the tvis manifold with a small port. Would this make any extra power? Would there be any complications?
I know this sounds very general, i've done a search but didnt find much, but are there any other problems that could slow down a 3sge.
Thanks in advance.
AW11 Track Toy
Formerly known as 1998
Caveman
Postby Adamal » Tue Nov 09, 2004 2:59 pm
Before you try new injectors, try some injector cleaner. You can get it for like $12 from Repco and its enough for 3 tanks worth.
If it doesn't make much of an improvement, its no biggie, only $12. Better than buying new injectors to find theres bugger all difference.
Of course, if then injectors ARE stuffed, the cleaner isn't going to make any difference. But yea, its a cheap test :)
Postby MrOizo » Tue Nov 09, 2004 3:51 pm
try timing, fuel filter, plugs, dizzy..
all them things and some other thigns im sure others will post..
i'll go with timing for now tho..
MrOizo
Toyspeed Legend
Postby Twolitre » Tue Nov 09, 2004 9:10 pm
The auto really kills the performance aye, try to find a 5-speed ST162 at pick a part and grab all the bits for a manual conversion, my first car was an ST162 GT and it used to love hills, I had a few basic mods and it felt quite a bit faster than both the 20v's I have driven and my old AW11
Any additional power the ST182 has is offset by the weight and so i would stick to the engine you have and put your money into the manual conversion.
If the injectors were leaking then you'd be overfueling by quite a bit and you'd probably notice a lot of black smoke and if one or more was stuck closed your engine would've died from detonation already.
Twolitre
Postby Caveman » Fri Nov 12, 2004 9:32 pm
Will a st182 manual box fit in a st162. I know (from what i've read) that all S boxes mate up perfectly but what about the mounts?
Has anyone done this conversion?
AW11 Track Toy
Caveman
Postby Chickenman » Fri Nov 12, 2004 9:45 pm
Is the car FWD? (I'm so ignorant tonight :roll: )
I've got a spare corona box in average condition..... somewhere.
Baby Jesus
Chickenman
I Am The Walrus!
Postby Caveman » Sat Nov 13, 2004 7:59 pm
Yea its a fwd.
Is the conrona box complete? I'd be very interested. The condition doesn't matter too much as long as all gears work and the synco's arn't too bad. I don't really trash my boxes.
I assume its a 5 speed?
AW11 Track Toy
Caveman
Postby Chickenman » Sat Nov 13, 2004 8:03 pm
I think you may need the clutch forks? I think the $&#$% at the workshop broke them. It didn't like changing into second from third that much... but wasn't too bad.
5 speed.
Also not sure about clutch/pressure plate etc.... Haven't had a look since I got my car back.
Baby Jesus
Chickenman
I Am The Walrus!
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
