Got to get a clutch done. how much should i expect to pay?
Postby Lunchie » Tue Nov 09, 2004 8:13 pm
Hi all if youve been reading my other posts ull know that i own a 1990 gt4 celica. I have discoverd that that clutch needs replacing in the nxt wee while and i want to get it done right. i drive pretty hard and so i want it to stand up to my abuse. What exactly should i have done? does the flywheel need machining and what should it cost all up and can any of you recommend some one in dunedin to do it. ive had some crazy quotes from places like turbo shop saying b.s like 16 hrs labour at 65 bucks an hour. Also im unsure as to whether i should go aftermarket, genuine toyota or Trd etc
Any help would be great
"The air is heavy with antisipation as cozmo revs, drops the clutch and...... stalls with the hand brake on"........ "cozmo's hand brake one, cozmo 0"
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1201 <----Click to see real POWER :P
Lunchie
Postby Silent Knight » Tue Nov 09, 2004 8:19 pm
Replace your clutch yourself...pretty easy job to do yourself.
As for going aftermarket that really just depends on how you drive it. If you thrash the clutch and race the car etc then i'd suggest going aftermarket. TRD tends to be a bit expensive but there are allot of other other cheaper good aftermarket brand clutches you can look at.
If you just plan on using the car as a daily driver and not do anything like raceing etc with then you can just go with an OE replacement wich should do the job just fine.
Silent Knight
Postby celica_tommo » Tue Nov 09, 2004 8:24 pm
16 hours is too much... An Exedy/Daiken clutch kit should cost $300 - $400, machining flywheel about $60 (Always recommended when you've got the gearbox off). I think most people consider an Exedy clutch to be at least as good as a stock toyota one if they are not exactly the same.
Is your clutch slippig?
celica_tommo
Postby Silent Knight » Tue Nov 09, 2004 8:26 pm
celica_tommo wrote:machining flywheel about $60
...that said most places will machine your flywheel for free if you buy the whole clutch kit from them. :wink:
Silent Knight
Postby Twolitre » Tue Nov 09, 2004 9:31 pm
The engine has to come out to replace the clutch in an ST185 so 16 hours is two days labour and is not unreasonable, like the others have said, do it yourself.
Twolitre
Postby da_jamo » Tue Nov 09, 2004 9:42 pm
Well i own a 96 celica, it cost me $400 4 my clutch and $50 for machining the flywheel. and thats just a new celica standard clutch......
da_jamo
Postby celica_tommo » Tue Nov 09, 2004 9:42 pm
TwoLitre is right actually... toyota repair manual says the engine has to be lifted out... lots of labour... means learning to do it yourself will save lots of money
celica_tommo
Postby Lunchie » Tue Nov 09, 2004 10:14 pm
lol taking the whole engine out myself is a bit on the crazy side ay considering i have no experience myself. Oh well thanks for the addvice. The quote ive been given for the clutch kit from most ppl is $550 si i dunno what to think. Where have the good old days gone with good old mechanics who dont try and screw a f**king 17yr old with no money out of an extra couple of bucks.
Lunchie
Postby celica_tommo » Tue Nov 09, 2004 10:22 pm
are you getting quotes from mechanics for a clutch kit or from auto parts stores?
celica_tommo
Postby Lunchie » Tue Nov 09, 2004 10:23 pm
from mechanics
Lunchie
Postby RS13 » Tue Nov 09, 2004 10:32 pm
Well, I'd say at a mechanics, you'd be looking at around $1200, I know on average a 4wd clutch is around there. If you knew a few people, you could organize a few beers and get them to give you a hand, taking an engine and box out is a bit of a mish, unless you have a hoist.
HTH!
RS13
Postby celica_tommo » Tue Nov 09, 2004 10:42 pm
Lunchie wrote:from mechanics
they might be adding a bit to the price... get a price from BNT and toyota... you can always supply the clutch kit yourself
celica_tommo
Postby Twolitre » Tue Nov 09, 2004 11:38 pm
Trade parts on the north shore in Auckland do a quality ST205 Exedy 3 piece replacement clutch kit for about $300 inc gst last time I bought one, this has a slightly uprated pressure plate over the ST185 and they machine the flywheel for free which obviously doesn't apply to you but ring them up and get them to courier it down to you, Partmaster, repco etc all wanted about $500 last time I checked.
Twolitre
Postby Just_Juzz » Wed Nov 10, 2004 7:58 am
Is it a 3S-FE or Ge? You don't have to remove the engine.
I just got mine done, 3S-FE, clutch kit, Exeedy clutch kit cost me $140+ (Retail $290) and one of the mechanics at work did it for me.
About 8 hours solid work.
Put the car up on engine stands, remove front axles (easy as hell), gear box out, cluth and flywheel out, machine flywheel, refit.
If you dont have axle stands, or a hoist, then it will be extremely hard for you to do it.
For a east/west engine, a mechanic quoted me $600 in labour.
But like I said, perky. So cost of labour unsure. But the engine doesnt need to be removed.
Current Ride: 1998 Caldina GT
Me, me, me, me.....
Just_Juzz
Postby Lunchie » Wed Nov 10, 2004 10:24 am
im not sure about that its the 4wd model so im pretty sure the engine does have to come out but ill ring toyota and get a quote on a part from them as im lead to believe the original toyota parts are pretty strong.
Lunchie
Postby celica_tommo » Wed Nov 10, 2004 11:26 am
Just_Juzz wrote:Is it a 3S-FE or Ge? You don't have to remove the engine.
3SGTE, 4wd. A FWD where you dont have to lift the engone is doable yourself for someone that has no mechanical experience and is willing to learn. But removing an engine and the cost of a hoist is a bit much.
celica_tommo
Postby Lunchie » Wed Nov 10, 2004 11:32 am
yeah dont worry i have decided to get the part from super cheap for 380 and the install is going to be around 450 all up including flywheel machining. But thanks for the suggestions anyway :D
Lunchie
Postby CozmoNz » Fri Nov 12, 2004 12:32 am
SUPERCHEAP?!? *SLAP*
lol
maybe kmart sell one :P
anyway, i paid $700 for my old subaru leones clutch (4wd turbo),... and 90% of the time subaru's are bitches and require the engine to be lifted, but i dont think they needed to, pretty open underneath.
Rayne For President!
CozmoNz
Postby rollaholic » Fri Nov 12, 2004 7:28 am
i'd be surprised if subarus needed the engine removed since they have a north/south engine layout
changing the clutch on a 4wd car is not trivial, and when the engine is east/west it just makes things that much harder. 16 hours does seem like quite a bit but if the engine really has to be removed then yeah, i'd say its about right.
Postby Just_Juzz » Fri Nov 12, 2004 9:29 am
My mates RS Twin turbo just had its clutch done, and since the gearbox is not underneath the engine, the engine doesnt need to be pulled out. The gear box comes out nice and easy.....
So yeah.
Me, me, me, me.....
Just_Juzz
