Hiring Spring Compressor in Wgtn
Postby Perky » Wed Nov 10, 2004 8:04 pm
Hi all,
Does anyone know where I could hire a pair of coil spring compressors (for suspension springs) in Wellington?
cheers,
Russell
Perky
Postby jacko » Wed Nov 10, 2004 8:09 pm
they are like $50 from repco arent they?
lickem.
jacko
Postby Perky » Wed Nov 10, 2004 8:15 pm
I think that both Repco and Supercheap have them for about $40, but since, all going well, I'll only need them for an afternoon, I would hire them if it's cheaper.
Actually, I also have a more techie question. What sort of grease should I use for a front suspension?
Russell
Perky
Postby hachi4drft » Wed Nov 10, 2004 8:18 pm
rubber grease
hachi4drft
Postby Perky » Wed Nov 10, 2004 8:19 pm
Thanks hachi4drft.
Perky
Postby [V8ROLA] » Thu Nov 11, 2004 7:08 am
did you find a set of compressors?? i have a set here you could borrow, are the shocks out of the car?? as you could just bring them round here and do them here i have the tools to do all that stuff, compressor, rattle gun etc.
just let me know if you need them still.
1995 ducati 900ss with a 2001 fuel injected motor, ramflow intake, open pipes, polished wheels and afew other mods.
more to come ;)
1983 RX7 series 2 with small block chevy.
http://photos.data.net.nz/?dir=V6ROLA%2 ... sion%20%2F
[V8ROLA]
Real Life Mechanic
Postby Wildcard » Thu Nov 11, 2004 9:39 am
Most equipment hire places have them.....
Wildcard
Toyspeed Founder
Postby Lunchie » Thu Nov 11, 2004 10:06 am
i heard that using a machine to compress/expand springs can be quite dodgy and that it can make them weaker but meh im not too sure about that and its way cheaper than buying new ones
"The air is heavy with antisipation as cozmo revs, drops the clutch and...... stalls with the hand brake on"........ "cozmo's hand brake one, cozmo 0"
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1201 <----Click to see real POWER :P
Lunchie
Postby celica_tommo » Thu Nov 11, 2004 11:10 am
Lunchie wrote:i heard that using a machine to compress/expand springs can be quite dodgy and that it can make them weaker but meh im not too sure about that and its way cheaper than buying new ones
No no no no no :) ... He wantsspring compressors which temporarily compess the springs to enable them to be taken off and put on the struts. Dont compress the springs and undo the top bolt and you can seriously injure yourself :?
celica_tommo
Postby Perky » Thu Nov 11, 2004 5:50 pm
That's right. I'm just replacing the shock absorbers.
I've checked a couple of hire places without success. I still have to call two more.
Thanks for the offer, V8ROLA. I appreciate it and may yet take you up on it. But if you're in Paraparaumu (are you?), it might be easier for me to hire them in town if I can.
cheers,
Russell
Perky
