caldinas
caldinas
Postby shaggz » Fri Nov 12, 2004 4:32 pm
hey my mate has jst got a manual 97 caldina gtt can sumone help me out how much boost can it run how reliable is the gearbox and driveline bits etc it seems to go alrite for a wagon,but hes curious as to the above questions etc
drive it till it breaks, then upgrade it
Santa Edit: Steve is the former owner of a man-card
shaggz
Postby Inane » Fri Nov 12, 2004 5:00 pm
Dont Run more than .9 bar with the standard engine management.
dont change the boost without disabling the vsv boost control,
the driveline and things are pretty strong,
as for going alright for a wagon, I wouldnt hesistate in saying that it goes alright "."
I could probably give you more info about this, but its 4:57pm on a friday afternoon.
also I suggest
"Click SEARCH" type in caldina GTT and you;lll get heaps of info.
Inane
Postby snwtoy » Fri Nov 12, 2004 7:55 pm
Woohoo! he didn't get it from buyright did he? there's a 97 manual there at the moment :)
snwtoy
nah
Postby shaggz » Sat Nov 13, 2004 12:06 pm
he brought it privatly from a guy in hammilton .9bar?????? wot does that equal in psi???? when he boosts it teh guage swings round to 13 but then settles on 9 psi wich i thought was a bit odd? i had a turbo starlet that i ran 11pounds in when yuo floored it the guage went to 11 and stayed there so i was curious as to the guage readings on his any suggestions why it does that???? goes up then drops back down????
shaggz
Postby CozmoNz » Sat Nov 13, 2004 12:11 pm
sudden rush of boost.... wastegate cant open as quickly ^_^.
i doubt that starlet had the same size piping as the caldina... more air.. at the same pressure...
Rayne For President!
CozmoNz
Postby Lloyd » Sat Nov 13, 2004 12:19 pm
1 bar = 14.7psi... roughly
sweet
Postby shaggz » Sat Nov 13, 2004 1:28 pm
yeah i know bot the pipe sizes etc and different turbs etc, i jst thought it was a bit weird it seems to happen even when yuo accelerate steadily not jst flooring it full noise,
shaggz
Postby YTWGN » Sat Nov 13, 2004 6:06 pm
Thats the VSV controlling the boost. It will stay open and close once the boost rises to about 12psi.
I had the same thing happen on my car. If you disable the VSV it will hit 8-9psi and just stay there.
YTWGN
Postby Inane » Mon Nov 15, 2004 9:14 am
mine sits at around 11 in 1st and 2nd, then up to 13 in 3rd and 4th...
Inane
how to disable????
Postby shaggz » Mon Nov 15, 2004 3:06 pm
how do you disable the vsv controller ???,i taped the boost in my starlet and he wanted me to do it in his caldina for him but it seems to have metal pipeign leading to the actuator not rubber like my starlet, so i wa wondering if its still possible, or do will it need a professional boost controller, not a t-junction and a bit of pipe???????
shaggz
