Supercharger oil was dead empty ?
Postby Lloyd » Sun Nov 21, 2004 9:32 pm
They hold 130mL of oil, 150mm-ish is standard size and yes you will notice quite a difference with a 175mm pulley kit. Just remember that if you put the bigger pulley on then you're overdriving the water pump, alternator etc
Postby LOMOFO » Mon Nov 22, 2004 10:43 pm
i Dont even know where the oil check or filler is for the s/c on my motor. what sort of oil does it take? has anyone else had problems with engine oil in the intercooler and pipes? im going to fit a catch can and see if it rectifies the problem but am not sure if this is a normal fault of these motors or if something is stuffed?
LOMOFO
