How much boost with standard 1G-GTE injectors?
Postby TygerTung » Mon Nov 22, 2004 2:09 pm
If you have the standard injectors and turbo's on a 1G-GTE engine, transplanted into a GA61 celica, what boost can you run without the injectors maxing out?
Also how much boost can the standard turbo's supply?
I think they are perhaps the smaeer injectors, can someone tell me what colour the injectors are for the various sizes, and what this can mean to me?
TygerTung
Postby Silent Knight » Mon Nov 22, 2004 2:13 pm
maximum boost on a gen3 1g is about 16psi plus or minus 1 or 2.
I think they normally run on 380cc injectors.
Silent Knight
Postby TygerTung » Mon Nov 22, 2004 3:04 pm
This is the 1G-GTE which was extracted out of a GA70.
So around 16 psi is usually sweet?
The standard intercooler isn't really up to the task though is it?
TygerTung
Postby Silent Knight » Mon Nov 22, 2004 4:23 pm
Standard cooler will up untill a certain point. It is not a very big cooler as you will already know but it does the job.
Looonie runs 16-20psi on and off and his boost cut differs depending on the weather. A hot or cold day will make the difference on where exactly you will hit boost cut.
The motor will handle 16psi sweet but I won't comment on how long exactly the turbo's will last as they are really really tiny. I've shat 4 CT12's when I had my GA70 and that was just running stock boost.
Silent Knight
Users browsing this forum: No registered users and 63 guests
