Fan not working
Postby AJz » Mon Nov 22, 2004 10:21 pm
If your able to, and you may not be, use a voltmeter to try and find the connection break, cos most likely a wire has broken.
If thats not possible just sort trace the wires seeing if you see any breaks.
I suggest you are carefull when poking around the wires though.
I had vtax :(
AJz
