Engine Diagnostics
Engine Diagnostics
Postby Audi » Sun Dec 05, 2004 2:38 pm
Which two ports do I need to connect to display the engine check lights? On my 3SGTE if it makes any difference.
Dig a hole for the next man and you'll fall in.
Audi
Postby Lloyd » Sun Dec 05, 2004 2:52 pm
E1 and TE1
Postby Audi » Sun Dec 05, 2004 7:44 pm
How do I know which ones they are?
Audi
Postby Al » Sun Dec 05, 2004 9:19 pm
the underside of the diagnostics cap will have a diagram
turn the key to on and then put the paper clip in :)
Al
Postby GT4 20 » Sun Dec 05, 2004 10:11 pm
If any fault codes do show up, you can either remove the ECU fuse for a few seconds or disconnect the -ve cable from the battery to clear them.
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby Audi » Mon Dec 06, 2004 11:24 am
Thanks. I thought there was a diagram on the top, just thought I'd ask incase I was wrong.
Audi
Postby Audi » Mon Dec 06, 2004 12:09 pm
Now heres a question I should have asked earlier. How do I know what is what?
Audi
Postby Audi » Mon Dec 06, 2004 4:02 pm
Ok I tried it and it just kept flashing. Whats that mean?
Audi
Postby Inane » Mon Dec 06, 2004 4:51 pm
if it just keeps flashing, I believe that means everything is A-OK
of course, if im wrong I'm sure some1 will correct me!
Inane
Postby GT4 20 » Mon Dec 06, 2004 7:51 pm
All fault codes are 2 digit numbers. It is possible for more than one fault code to be stored at a time.. Below is an example of how a check engine light would flash if codes 12 and 43 were stored. The "......" represent the length of time between the flashes and the "#" represents the flashes.
Once you take your time and study the check engine light, it is easy to read the fault codes.
Now, rather than put all the codes down here (there are 19 of them), count the numbers and let me knwow what they are and I'll confirm the diagnosis.
HTH
Gray
GT4 20
Postby levin_it_large » Fri Dec 10, 2004 9:49 am
sorry to sound like a noob but do u put a paper clip in each of E1 and TE1 and connect that to what or am i completely wrong?
levin_it_large
Users browsing this forum: No registered users and 38 guests
