help me identify these 3a parts...
Postby wannabe86 » Mon Dec 06, 2004 7:11 pm
i'm removing the 3a to put in a 4agze in the ae85 (finally).
First: the pipe that goes from brake booster to the exuast manifold? what does it do?
Second: the black canister inbetween the radiator and window washer container: what is it and is it only for the 3a? it has an overflow that sticks out under the car?
sorry not got camera so can't take pics
thanks
wannabe86
Postby Lloyd » Mon Dec 06, 2004 7:24 pm
You sure the brake boost isn't to the inlet manifold? If so then its because the booster needs vacuum to boost the pedal pressure you apply basically
Postby wannabe86 » Mon Dec 06, 2004 7:44 pm
i see. you're right. it does.
wannabe86
