Adjutable coil overs
Postby mad starlet » Thu Dec 09, 2004 9:37 pm
Hey
Does anybody know if ae101, ae111 adjustable coil overs would fit in a ae92 levin
thanks
mad starlet
Postby 88gtz » Thu Dec 09, 2004 10:31 pm
Yes they will, i have ae101/111 coilovers in my AE92
88gtz
Postby CITIZEN » Fri Dec 10, 2004 7:01 am
you for real? not ss aye? :?
CITIZEN
Postby ChaosAD » Fri Dec 10, 2004 9:29 am
Aparently the fronts are the same for all AE series cars. But if the rears are SupreStrut then they wont fit non superstrut.
ChaosAD
Postby TRD Man » Fri Dec 10, 2004 9:43 am
Other way around ChaosAD.
TRD Man
Postby ChaosAD » Fri Dec 10, 2004 10:52 am
k thats the last time I post something I learnt off toyspeed.
I read somewhere on here that the superstrut was at the back, thought it seemed a bit strange.
So can you use the ae101 rear struts on an ae92? or dont they have the swaybar mounting points.
Assuming your looking at those king/koni adjustable platform coilovers, and assuming that they are using a shock insert. You should be able to either get the struts modified or get the inserts & threaded brass tube changed over to your struts.
Youd want to find out for sure first though, and find out if its worth it.
ChaosAD
Postby Mr Revhead » Fri Dec 10, 2004 1:03 pm
s/s is on the front, there are differences in the rear parts but only as far as shock valving and bushes etc, the parts bolt over no probs
Postby TRD Man » Fri Dec 10, 2004 2:38 pm
Except AE82. They're different in the rear.
TRD Man
Postby mad starlet » Sun Dec 12, 2004 10:18 pm
i have TEMS suspesion so will this be a problem
mad starlet
