Torsen Diff Oil - what you reccomend?
Postby MrOizo » Tue Dec 14, 2004 9:06 am
as the topic..
which oil should i be using for the torsen rear in the supra?
some have said a mix of ATF and box oil...
From Stuart W from SCONZ wrote:I personally run a 50/50 mix of ATF and 80/90 hypoid (sp?) LSD gear oil, the
ATF lowers the losses, and the viscosity is less critical in a torsen as it
does not rely on clutches to work, unlike a normal LSD.
Seems to work well for the 100,000 K's I've put on the car :)
Stuart W.
any suggestions?
MrOizo
Toyspeed Legend
Postby Twolitre » Tue Dec 14, 2004 5:16 pm
Do you have a sticker under the bonnet which tells you what grade and how much? or know anyone with a jap owners manual, I'd stick to what toyota reccomends but at least you don't need a specific lsd gear oil.
I just use a GL5 80W-90 in my Torsen
Twolitre
Postby vvega » Tue Dec 14, 2004 5:24 pm
just run a hypoid diff oil
not a lsd oil :D
vvega
