ke70 - ae86 brake setup
Postby MetalupYoAss » Tue Dec 14, 2004 9:20 pm
ae85/ae86/ke70 struts are the same, ae85 and ke70 brakes are the same too, the spring rates vary but are interchangeable also...
shortstroke your ke70 struts with ae92 inserts (about $60) fill them with motor oil, use your king springs and the ae86 brakes; upgrade the front bushes and wind up the caster rods.. it'll stick like shit to a blanket
MetalupYoAss
Postby dxtawagon » Tue Dec 14, 2004 9:49 pm
its already running 4age, standard breaks work alright and its got cert with standard brakes but want to upgrade a bit.
Like metals term stik like shit to a blanket!
ive got damper adjustable konis and kings in at the mo but might have a look into this ae92 insert buisness
cheers for the info guys
dxtawagon
