hole in exhaust?
Postby minijrocks » Wed Dec 15, 2004 2:10 pm
i dont think it is detonation. it has a little ping at like 4000 rpm then again at like 5500.... i might take it 2 exhaust shop, see what they reckon, just have a quick look
minijrocks
Postby kingcorolla » Wed Dec 15, 2004 3:43 pm
minijrocks wrote:i dont think it is detonation. it has a little ping at like 4000 rpm then again at like 5500.... i might take it 2 exhaust shop, see what they reckon, just have a quick look
id suggest you not, as they will probably not define the problem. They will probably 'suggest" you replace your flexi/cat watever as that 'could' help the problem.
They are not mechanics. Just define your problem before your spend :wink:
does it do it under load? (eg accelerating) or will it make the noise whist reving in neutral? Exhaust leaks are usually a constant noise, rather than specific points, and will leak under any curcumstances. (eg load, no load)
1983 Carina AA63 4age
kingcorolla
Users browsing this forum: Bing [Bot], Google [Bot] and 56 guests
