longer studs? hilux
longer studs? hilux
Postby dxtawagon » Wed Dec 15, 2004 6:57 pm
ok, ive got some ae86 struts and brakes etc to go into my ke70, got them apart and takn the disks off the bit with the studs (sorry dont know technical term), but how do i go about getting the old studs out and where do i buy some longer studs and fit them.
dxtawagon
Postby UTERUS » Wed Dec 15, 2004 8:18 pm
To try and get them out tighten 2 nuts together on the stud and try and undo it that way, if you dont want to use the stud again try vice grips. Or hit them with a big hammer and see if they fall out.
It is a myth that emos are contagious, and you may be infected. However, it is still widely accepted to wash your hands after physical contact
UTERUS
Postby THA SHZ » Wed Dec 15, 2004 9:49 pm
To get the studs out of the hub u should be able to just hit them out but as for puttin in longer studs u will probably have to take the hub apart and then press fit it back once u finished as u probably wont be able to manovre them in otherwise which also means ul probably have to replace ur bearings as well :D
THA SHZ
Postby Lloyd » Wed Dec 15, 2004 9:57 pm
Hammer to get them out and to get them back in just get a spacer (nut thats too big) and put the wheel nut on to pull them right in
Postby THA SHZ » Wed Dec 15, 2004 10:05 pm
But wit the longer studs u may need to pull the hub apart :D
THA SHZ
Postby evil_si » Wed Dec 15, 2004 10:47 pm
the studs will as said 'just push out' with a decent couple of hits.
as for longer ones, auto one for instance sell a variety of studs, all different lengths and thread types etc, just try and match something up.
as for getting them back in, if they will go in with out disassembling the hub just use a spacer and wheel nut and pull them through,
other wise its all gotta come apart
evil_si
Postby dxtawagon » Thu Dec 16, 2004 7:50 am
thanks for that, ive got it all apart so ill try with a hammer 2night, cheers
dxtawagon
