4AG Bluetop - Oil Press./Temp. Gauges - Any Issues?
Postby AceSniper » Fri Dec 17, 2004 7:25 pm
them Block adapters are hard to find, I found one but it didnt fit, an no one else had ever seen one before, so instead Im getting the factory adaptor that comes off the block that the filter screws into drilled an taped for a oil feed line an run the presure sensor on the end, could put a T there for a temp one to...
AceSniper
Postby FLAWLES » Sat Dec 18, 2004 9:39 am
im " going to be " runing a oil cooler on my ze i plan to run the oil temp sender in a brass t fitting with braded lines this should do the trick
as for the oil press ive got a electric one that i have monted a realy smalle braded nilon hose into the block and i have run it around to were the water tank is for the windscreen wippers and mounted it there with the sender.
latter on when the cooler is hooked up i will move the sender there with the temp sender
FLAWLES
